Fuel cut?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-05-2006, 08:39 PM   #1 (permalink)
View NU2MR2's Photo Gallery
Fuel cut??
So here's the deal;
It boosts to about 6 or 7psi and then it feels like someone slammed on the brakes and the check engine light comes on! Then the light goes off and if I step on it, it feels kind of like it's flooding itself(doggy), and as soon as it starts to boost again it does the same thing! Could this possibly be the O2 sensor? Or if the vacume line to the MBC is pinched would this happen? Or a loose clamp on the intercooler piping?
NU2MR2 is offline   Reply With Quote
Old 04-06-2006, 01:33 AM   #2 (permalink)
Pure Performance
View just_BLAZE's Photo Gallery
If it were a fuel cut, i believe pre-programmed from the manufacturer with a ct26 the fuel cut was at 12-12.5psi and the CEL would come on. And to reset it you would have to disconnect your battery then hook it back up to clear it and revert it back to normal.
just_BLAZE is offline   Reply With Quote
Old 04-06-2006, 01:48 AM   #3 (permalink)
Boosting 15 psi :)
View Drifting Dane's Photo Gallery
the same thing happened when i installed my EBC... it was either fuel cut, or AVCR tuning (im not sure as i did both at the same time)
If you have a manual BC, then it is your fuel cut... ace hardware FTW!
Function over form.
Drifting Dane is offline   Reply With Quote
Old 04-06-2006, 01:53 AM   #4 (permalink)
Pure Performance
well what was your boost set at? do you have a fuel cut defencer? but if the same thing is happening like the original poster then i don't know.
Old 04-06-2006, 02:20 AM   #5 (permalink)
Boosting 15 psi :)
It doesnt really matter what the boost was set at because i was just getting out of vacuum when my car bogged and the check engine light came on. (i beleive it was set at .8 bar for tuning/testing)
As stated above, i didnt have fuel cut in my initial tuning (an oversight)
Function over form.
Old 04-06-2006, 09:09 AM   #6 (permalink)
What is FTW? Do you still think it would still fuel cut even if I disconnected the MBC? How hard is it to install a fuel cut defenser?
Old 04-06-2006, 11:02 AM   #7 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
Fuel cut happens at 12 psi on the 91/92 mr2s and 16 psi on the 93+ mr2s.
If you hit fuel cut ONCE, you will keep hiting it at ANY positive pressure until you turn the car off and back on.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 04-06-2006, 11:44 AM   #8 (permalink)
But I never even made it to 12psi...I barely hit 7! Any idea what could cause this?
Old 04-06-2006, 11:56 AM   #9 (permalink)
I love Cin
How are you measuring boost?
Do you have an accurate gauge?
Where is it taking it's reading from?
Old 04-06-2006, 12:08 PM   #10 (permalink)
I have an aftermarket boost gauge and its tied into one of the lines that runs off the intake manifold(turbo intake side).
Old 04-06-2006, 12:12 PM   #11 (permalink)
I love Cin
It sounds to me like you are absolutely hitting fuel cut. This issue would have nothing to do with your O2 sensor as the O2 sensor only affects things at idle and cruise, not under significant throttle.
I would be skeptical of your boost gauge or it's install. If the line to that is pinched, it may not be reading accurately.
Does it read vacuum? If so, what's it read at idle?
Old 04-06-2006, 12:38 PM   #12 (permalink)
Yes it reads about 23. I think, I only worked on it yesterday. What vacume line(s) should be going from the bov and where? Does having a MBC change these?
Old 04-06-2006, 12:44 PM   #13 (permalink)
I love Cin
You should not be playing with the vac lines on the BPV at all.
Having a MBC does not change the fuel cut set point.
You vac sounds good.
To see the OEM vac lines, see here:
http://mr2.noegruts.com/engine/engine.htm
Old 04-06-2006, 05:46 PM   #14 (permalink)
Boosting 15 psi :)
FTW = for the win... sorry. As Jeff said, once ou hit fuel cut once it continues to do so at any positive pressure. The installation for my FCD (from Ace hardware) took about 20 minutes in the dark... its easy, jsut search the board for the different ways to do it.
Function over form.
Old 04-06-2006, 08:27 PM   #15 (permalink)
Thanks.
The only reason I asked is because in most of the pictures I've seen; people with aftermarket BOVs only have one line from it and the VTV valve isn't there...Why would people do this?
Carburetor fuel cut solonoids - mixed up? larrymoencurly Archived Corolla threads 1 02-21-2006 07:53 PM
getting rid of fuel cut bad7mgte Supra Forum 10 11-22-2004 10:16 PM
Fuel Cut 91 turbo MR2 Forum 5 08-09-2004 08:24 PM
Fuel cut question.... Piddy MR2 Forum 2 08-05-2004 08:21 AM
