Clutch help!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-09-2006, 09:19 AM   #1 (permalink)
92 MR2 Turbo
Zero turbo's Avatar
View Zero turbo's Photo Gallery
Exclamation Clutch help!!
I was racing all night and when i was about to go home I press the clutch to start the engine and when i de-press the pedal the pedal was stuck down it didnt came up i had to pull it up with my hand. so when I was shifting the peadal was coming only half way up then i had to pull it with my feet.When i got home the pedal comes up normaly but when you press it hits the pedal wall really fast and dosent do anything i cant get it into gear i am stuck in neutral.I hope is the pedal cable.......
1-Chuck Norris is the reason why Waldo is hiding
2-When Chuck Norris does a pushup, he isn’t lifting himself up, he’s pushing the Earth down
3-The Guinness World Book of records shows the people that have come the closest to the skills of Chuck Norris.
Zero turbo is offline   Reply With Quote
Old 04-09-2006, 09:55 AM   #2 (permalink)
Autox addicted
Ilovemymr2's Avatar
View Ilovemymr2's Photo Gallery
sounds like ur clutch is gone or the clutch pump is dead.
Ilovemymr2 is offline   Reply With Quote
Old 04-09-2006, 04:14 PM   #3 (permalink)
View clem's Photo Gallery
yeah guy its a clutch it happened to me before too
clem is offline   Reply With Quote
Old 04-09-2006, 11:39 PM   #4 (permalink)
92 MR2 Turbo
Zero turbo's Avatar
well if it is the cluth would it be a good idea to put this one in my car http://cgi.ebay.com/ebaymotors/F1-RA...55063721QQrdZ1
my car is stock...
Old 04-10-2006, 12:29 AM   #5 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997475
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
We have hydraulic clutches in our cars. it's probably the clutch master cylinder or/and clutch slave. even if it's just one of those components, the other one is probably not far behind. I recommend changung out both units...they can be rebuilt, but I would get new ones ..
as for a temporary fix, you might try changing the fluid in the system. it's probably very old and/or contaminated making it lose it's ability to hold pressure. that may or may not work. all you can do is try and it won't cost you but some fluid.
The Jedi Speeder at CarDomain
Old 04-10-2006, 03:51 PM   #6 (permalink)
View Gairloch's Photo Gallery
^^ x2
You bleed it from the slave cynlinder that's next to the front engine mount. If you boiled the clutch fluid swapping out the fluid might just do the trick.
All you need is some normal DOT 3 brake fluid.
"Our Lady of Blessed Acceleration, don't fail us now!" -Elwood Blues
Gairloch is offline   Reply With Quote
Clutch problem, seeking help. blueapple Celica Forum 0 01-21-2006 12:17 AM
UPDATE: Clutch problem canadianae92 Archived Corolla threads 2 10-29-2005 05:13 PM
My clutch has started slipping and I dont know why REAPER STRAIN Camry & Solara Lounge 55 09-19-2005 07:47 AM
new clutch = broken wallet eyz closd MR2 Forum 4 03-12-2005 04:16 PM
