spark plug Q? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-09-2006, 06:34 PM   #1 (permalink)
View jesse0880's Photo Gallery
spark plug Q?
in my 91t mannual, it calls for a bkr6ep8 number on for the spark plugs ( ngks of course). i bought a set and they have bkr7e on them. Can these be a newer brand of ngk's for the mr2's or are these plugs the wrongs ones?
jesse0880 is offline   Reply With Quote
Old 04-09-2006, 06:54 PM   #2 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
those should be okay in ur car...same ones i use....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 04-09-2006, 08:27 PM   #3 (permalink)
3SGTE & 1GRFE
View NESW20's Photo Gallery
those are what i have in my MR2.
-Mike
1991 MR2 Turbo 2.1L stroker
2006 Tacoma D-cab 4x4 Auto TRD Off Road
NESW20 is offline   Reply With Quote
Old 04-10-2006, 12:36 AM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997475
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
me too
The Jedi Speeder at CarDomain
Old 04-10-2006, 09:57 AM   #5 (permalink)
Noob :-)
View ST185's Photo Gallery
"7" in the BKR7E indicated heat rating of the plug.
The higher the number, the colder the heat rating.
The colder plug works better in high boosting engine.
Stock 3sgte is "6" heat rating.
BKR7E will work fine and should be better when you turn up the boost.
The only drawback is you might have a little trouble starting (longer cranking time)
when the engine gets really really cold. (which shouldn't be the case in CA)
93 ST185
ST185 is offline   Reply With Quote
Old 04-10-2006, 02:10 PM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
oh, so thats what the 7 means? thanks for the info/education ST185....Thats why I love this forum!
Old 04-10-2006, 04:38 PM   #7 (permalink)
Noob :-)
You're welcome.
There is lot of info on NGK site
It's a very good read and will clear up most misconceptions about spark plugs.
http://www.ngksparkplugs.com/techinf....asp?nav=31300
and here is how to decode the NGK plug (in pdf)
http://www.ngksparkplugs.com/techinf...tnumberkey.pdf
93 ST185
Old 04-11-2006, 12:22 AM   #8 (permalink)
thanks guys. now i can switch out the bosches that snuk thier way into my engine...LOL
Help!! Removing stuck spark plug in Camry 2.2 skewe Camry & Solara Lounge 23 06-04-2007 05:45 PM
How to remove a broken spark plug on my '93 Camry LE V6? Vibroseis General Discussion 4 03-03-2006 03:47 PM
Oil on one spark plug bronzemaxell Camry & Solara Lounge 16 12-06-2004 09:08 PM
spark plug wires + spark plugs aleks77 Camry & Solara Lounge 4 09-13-2004 02:08 PM
Spark plug wire boot ']['R][) camry Camry & Solara Lounge 10 04-18-2004 12:59 AM
