ATTN: owners of GReddy Turbo Timers - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-13-2006, 10:53 PM   #1 (permalink)
aka "Downforce"
View Strat42586's Photo Gallery
So I bought a GReddy turbo timer from a friend, and I bought the harness. But apparantly there is a third harness that connects the turbo timer to the main wiring harness. Reworded: there are four male prongs on the turbo timer connector, and a different pattern of three female prongs on the wiring harness. If anyone with a GReddy TT knows what I'm talking about, I can't find that middle adapter harness for sale anywhere . Can someone tell me which color wires from the main harness connect to which color wires on the turbo timer, so if I cut off both connectors, I could just solder the corect wires together?
Strat42586 is offline   Reply With Quote
Old 04-14-2006, 10:05 AM   #2 (permalink)
Noob :-)
View ST185's Photo Gallery
You should be able to find the main connector under the ignition key.
You will have to remove the plastic panel under the steering wheel.
It's somewhere under there.
The safty feature wires are there to shut off the engine incase that
the parking brake is disengaged or the car is moving.
You don't need to connect the safty feature wires.
The TT wil work fine without them.
93 ST185
ST185 is offline   Reply With Quote
Old 04-14-2006, 01:53 PM   #3 (permalink)
aka "Downforce"
I know how to install it, but my problem is that the harness labeled "This one goes to turbo timer" doesn't directly plug into the turbo timer. There is an adapter harness between the two. I do'nt have that adapter harness, so I need to know what wires the adapter harness connects to what other wires.
Old 04-14-2006, 02:21 PM   #4 (permalink)
Noob :-)
OK I see.
And I fix the pic, those were not the safty feature wires
I'm not sure which Greddy TT you have but this is the most likely.
There should be 7 wires from the TT
Red - Red - 12V (ignition)
Blue - Blue - ACC (ignition)
Green - Green - ON (ignition)
Black - Ground
Gray - disregard (Japanese car only)
Brown - parking break
Purple - speedometer wire
93 ST185
Old 04-16-2006, 08:14 PM   #5 (permalink)
aka "Downforce"
Righteous man, exactly what I needed. Thank you.
GReddy Turbo Timer Strat42586 MR2 Forum 1 12-16-2004 01:02 PM
attn: ae92 owners boroEF Archived Corolla threads 20 11-08-2004 09:05 PM
86.5-92 supra turbo question for owners of these tbone36109 Supra Forum 9 09-07-2002 06:44 PM
