installing ground/earth wires - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-17-2006, 09:38 PM   #1 (permalink)
View mr2poweraw11's Photo Gallery
Gen1 installing ground/earth wires
i got some crappy knock offs of hks wires on ebay, anyone know how to install them? i keep hearing its easy, just connect them to the chassis, then to the valve cover, then to the alternator, and some guy said to my nipples, im tired of all this, anybody know where exactly? help would help. thanks.
mr2poweraw11 is offline   Reply With Quote
Old 04-18-2006, 07:59 AM   #2 (permalink)
BRAKE/STEER/THROTTLE
ToyotaTechGeek's Avatar
View ToyotaTechGeek's Photo Gallery
i went from the chassis to the AFM, i went to the battery to the trans/block. i went from the head to the block. the coil, the igniter and the chassis, then to the head near the valve cover. i also added a strap from near the SC inlet to the intake manifold near the head. for chassis grounds, i scraped all of the paint from underneath the bolt i was using. after installing the ground strap, i sprayed the area with CRC 656 Marine grade lubricant/dessicant. i also added a ground strap from the ECU case to another chassis ground. i made my own grounding 'system' (haha) and used all flat braid wire ranging from 14 AWG-00AWG.
ToyotaTechGeek is offline   Reply With Quote
Old 04-18-2006, 02:52 PM   #3 (permalink)
thanks
Old 04-21-2006, 05:46 PM   #4 (permalink)
anyone gotz pictures? toyotatech? makes life a little easier.
Old 04-21-2006, 08:03 PM   #5 (permalink)
i have an SC, so it'll be different.
not to be a jerk, but it's pretty self-explanatory, but here you go anyway:
chassis=sheetmetal
head= aluminimum top half of engine
block= bottom half of the engine
transmission= not the engine
afm= about where most people do some sort of cone airfilter
ecu= car computer underneath the grey cover in the boot (trunk)
Old 04-22-2006, 12:55 PM   #6 (permalink)
i was just concerned on the afm and ecu portion of it, i know your not a jerk, but i never had much luck working on cars, im a guy who had his hand crushed by the headlight cover trying to change the headlights, im i will never look at my care the same way.
Old 04-22-2006, 06:21 PM   #7 (permalink)
i just lightly sanded the afm body next to a mount, then i used the spot to mount the strap and then i went to the chassis where i also attached the negative battery cable.
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 11:48 AM
90 Prizm Engine Removal - the wires? tashirosgt Archived Corolla threads 6 04-20-2006 09:22 PM
Tercel Clock wires? Help? gezebo Tercel, Paseo, Starlet, and Sera Forum 7 01-03-2005 03:44 PM
My dash lights went out! xavior66 Camry & Solara Lounge 5 08-03-2004 01:38 AM
