sounds like you have a smallport from japan
to use the oil cooler you will need to swap the oil filter housings AND the oil pan
to have the engine run correctly you will need to use all of the stock mr2 electronics.. including the injectors (would be best if you can find some low ohm 250cc/min topfeed injectors)
the intake manifold will NOT fit from the old motor onto the new motor.
