rebuilding my ct26 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-20-2006, 07:32 PM   #1 (permalink)
tamalpro
View tamalpro's Photo Gallery
rebuilding my ct26
i want to buy a ct26 rebuild kit ,do i need special tools for the rebuild? where can i fin a bigger compresor wheel? do i need to machine the turbo for the bigger wheel?
tamalpro is offline   Reply With Quote
Old 04-20-2006, 09:47 PM   #2 (permalink)
jdm 2nd gen ftw!
View nepopolus's Photo Gallery
i may be having this done to my ct-26 rebuilt with a bigger compessor wheel but the guys at the shop doing my engine swap said it can break easy because the shaft is alot smaller then it should be for the power it can put down
this is why i may be investing into a total new upgraded turbo from them witch was proven to support over 560hp
nepopolus is offline   Reply With Quote
Old 04-20-2006, 09:58 PM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997475
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
I would let a competent machine shop experienced with turbo chargers do it.. after the rebuild the shaft MUST be balanced. turbos can reach 100k rpms...the clearance for both compressor wheel and turbine wheel is critical
I think your info is wrong with the assumption that you can reach 560 HP with a modified CT26. the turbine side of the turbo is just to small and restrictive to flow that much exhaust...
The Jedi Speeder at CarDomain
Old 04-20-2006, 11:16 PM   #4 (permalink)
tamalpro
still wating
im still wating for an answer
Old 04-21-2006, 10:07 AM   #5 (permalink)
jdm 2nd gen ftw!
o..i must have typed bad (what a suprize) i ment that i will either rebuild my ct-26 or buy a new turbo
o btw yes you do need special tools to do it right,you can probly find bigger compressor whels on ebay, and yes you will need to make the trim bigger on the turbo to make it fit right (this is very touchy and why you bring it to specialist so it is done right )
MRQturbo... CT26 turbo questions? micro214_kp61 MR2 Forum 4 07-28-2004 06:21 PM
Askin about the CT26 NDR008 Celica Forum 0 05-07-2004 07:56 AM
FS: CT26 upgrade to Garret T04E, cheap! celica_speed Supra Forum 2 03-07-2004 10:49 AM
