Originally Posted by tamalpro
ok i belibe you that it should be at the intercooler but, why the seller says that the closer to the throtle body the bettery
I don;t care what I say ro what the seller says, I care about what the
manufacturer of the water injection systems says. Go to Aquamist's Web site and read for your self.
Just so I am clear, it needs to be AFTER the IC.
You do not want the water shooting into the IC.
Originally Posted by ST185
It should be after the IC and far away from the TB as much as possible.
This will give more time for the water to vaporize. The vaporization will remove heat from the charged air.
Sorry, but that is incorrect. You want it as far from the TB as possible so the water has the maximum time to disperse. If you put it to close to the TB, the water will not be as evenly distributed throughout the air stream.
You do not want the water to vaporize before it gets to the engine. You want the combustion process to force the water into a gaseos state so that it absorbs the heat inside the engine.
