some (slow) progress... pix - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-25-2006, 12:34 PM   #1 (permalink)
Gameroom cash: $134355
"new" engine:
from a running 86 ae86 (which that car got a motorswap for more power, not running issues), changed some seals/gaskets/waterpump/belts.... etc
the mr2 "shrine" (all parts on/under this are from mr2's... and i have tons more parts)... the tranny on the right is the new tranny for this car
rear (cheap ebay) miata coilovers installed... full height
in the car.... now it just needs a crank pulley, driver side mount, bolt on the starter/exhaust manifold then it *should* start
front coilovers done too... really should cut the perch & have it welded lower.... when i change strut inserts on it i will do this as well
random
Old 04-25-2006, 01:42 PM   #2 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
good work..i wish i had the time/space/knowledge to do all my own work.....kudos to you..get this baby running....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 04-26-2006, 02:15 AM   #3 (permalink)
"rebuilt" the starter to working specs
with starting fluid.... she lives.... either FP or out of gas.... gas light is on and the car is at a forward angle... gonna get some gas in my can tomorrow....
Lookin 4 pix of the gen 4 EVO body kit (2 pix inside) and Need ur opinion :) aleks77 3rd & 4th Generation (1992–1996 & 1997–2001) 19 04-15-2007 10:20 PM
slow forum since last weekend...... subliminaltrips 89-95 Toyota Pickup/Hilux 6 03-04-2006 11:57 PM
some pix of the (in progress) spraypainted 87 mk1 sc :) toyotaspeed90 MR2 Forum 8 09-20-2005 06:25 PM
1990 Camry thermostat slow to warm up, slow to go into overdrive 38dean 1st & 2nd Generation (1983–1986 & 1987-1991) 2 10-09-2004 02:11 AM
