thnx 4 the probpt replys. well, i'm 95% positive im gettn it. if i cld get the name or sumway of contacting the guy with the 400rwhp 4agte that would be great! unless i tlk to that guy or sumone changes my mind, i thnk i am going to go with the 4age silver top, a modified t28 for now, megasquirt, larger fuel pump, injectors, rail, change to edis ignition so megasquirt can cntrl my ignition. so whats the deal with the e-series tranny? how much will my factory one hold... im tld its just been rebuilt and new clutch and all that gd stuff. is the e-series tranny just a newer one such as one that wld cum with the silver top? i'm also tld he just had new aftermarket springs on it... i dont remember what brand, but he said he's done some other suspension related mods as well. basically the only real problem with the car is that a tranny mount is broke, the engine mounts need replacing soon, the valve cover leaks, a cvjoint leaks, and it burns oil at the higher rpm range... i'm guessn the rings are gettn bad. ne thoughts as to my plans? all chriticism welcome! thanx again, and thanx in advance. i'm very excited 'bout this project.
