Code 24 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-06-2006, 06:58 PM   #1 (permalink)
View Mr2SlOw...'s Photo Gallery
Code 24
Can any1 tell me what this code means and what I can do to fix it.... also I would like to know some of the symptons that can occur due to this code so I can know if this is the cause of my problems....
Mr2SlOw... is offline   Reply With Quote
Old 05-06-2006, 08:17 PM   #2 (permalink)
Noob :-)
View ST185's Photo Gallery
Code 24 is the temp sensor in the AFM.
It could be short or broken wire between AFM and ECU.
Take the AFM out and check the resistance.
You can also use a voltmeter to check the voltage.
The procedure is listed in the BGB.
93 ST185
ST185 is offline   Reply With Quote
Old 05-07-2006, 12:03 AM   #3 (permalink)
OK so your sayin i should take out my MAF and then check it for voltage??? do you know if this code can make my car start up for about 5 seconds then turn off???? Even when I try to rev its like the more I press the gas it still stays in the same RPM about 2-3K even at half throttle... running rich while doing soo and sounding like a machine gun a loud loud machine gun.... then as soon as I give up and let go off the gas its just turns off????
Old 05-07-2006, 04:00 AM   #4 (permalink)
Noob :-)
Yes, it will start up and turn off.
Here is how you check the AFM
http://www.alltrac.net/phpBB2/viewtopic.php?t=13218
93 ST185
Old 05-07-2006, 06:16 PM   #5 (permalink)
I fixed my code 24 with a little soldering in the AFM but now I got a new code... i got a soft code 43 .... I still turn on the car and it turns on for about 3 seconds then it turns off again... what would this have to do with my starter????
Code P0110? JohnSWA Camry & Solara Lounge 9 09-15-2009 10:16 PM
Code 24 and 31 fourteen Tercel, Paseo, Starlet, and Sera Forum 2 02-02-2006 01:26 PM
why am i getting code 52 eyz closd MR2 Forum 7 01-10-2006 08:36 AM
Check Engine light Code 25 & 26, please HELP!! xaznxeclipsex MR2 Forum 0 06-01-2004 08:46 PM
ecu trouble code Nx2k Archived Corolla threads 1 02-12-2003 06:36 PM
