3sgte gen 3 help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-07-2006, 02:02 PM   #1 (permalink)
MAX BOOST!!!!!!!
View mr2_dori's Photo Gallery
2nd Generation 3sgte gen 3 help
im wanting to buy new distrib cap and spark plugs. new spark plug wires. any help on what i should get. is the gen3 motor special order stuff. or are these the same parts of the gen 2 engine
mr2_dori is offline   Reply With Quote
Old 05-07-2006, 02:05 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998275
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
OEM ignition parts are just as good as aftermarket for stock and mildly modded 3sgte's and for 1/2 the price.
The Jedi Speeder at CarDomain
Old 05-07-2006, 02:10 PM   #3 (permalink)
MAX BOOST!!!!!!!
2nd Generation
so i can go and order 3sgte gen 2 parts for the gen 3 3s. and it should be ok
Old 05-08-2006, 10:11 PM   #4 (permalink)
Ontario's King of AW11
View yellow86MR2's Photo Gallery
the cap and rotor are the same. The wires on the ends that go to the dizzy have a 90 degree bend. On the gen2 they go straight out.
If you order for a 93-95 US car, than you will get the proper "gen 3" wires. I'm running gen2 wires on my gen3 and it works....but i'm not using the platic trim cover that covers the wires in the middle of the valve cover.
Martin
yellow86MR2 is offline   Reply With Quote
Old 05-09-2006, 11:39 AM   #5 (permalink)
MAX BOOST!!!!!!!
2nd Generation
thanks you for your help. and what about the spark plugs. not wires.
Old 05-10-2006, 07:19 AM   #6 (permalink)
for plugs you can go with something like NGK coppers. BKR7E. They are 1 step colder, cheap to get and work great. Ideal if you are running more than stock boost.
Martin
Old 05-10-2006, 12:29 PM   #7 (permalink)
MAX BOOST!!!!!!!
2nd Generation
well thank you for your help yellow86MR2. just want to let you know, that you have an awsome aw11. i think that will be my next car to fix up.
Old 05-10-2006, 01:21 PM   #8 (permalink)
View Mike@Fidanza's Photo Gallery
Martin
personally i'd go with just a standard NGK plug! the coppers are more expensive and just burn up quicker!
Mike@Fidanza is offline   Reply With Quote
Old 05-15-2006, 07:56 PM   #9 (permalink)
View Gairloch's Photo Gallery
?!? you thinking of something else? These plugs cost a whopping $2 (or less) each.
"Our Lady of Blessed Acceleration, don't fail us now!" -Elwood Blues
Gairloch is offline   Reply With Quote
GEn 4 camry solars glow guages ona gen 4 reg camry mystickid 3rd & 4th Generation (1992–1996 & 1997–2001) 15 05-18-2005 05:06 PM
Gen 4 MAF on gen 3 car mobes 3rd & 4th Generation (1992–1996 & 1997–2001) 2 11-06-2004 06:28 PM
How do I wire up an 3sgte Map sensor on 5sfe Gen 3 Camry? Camdaddy 3rd & 4th Generation (1992–1996 & 1997–2001) 1 03-03-2004 01:01 AM
