I guess it could be possible that I connected it to the wrong wire. When I pulled off the center cover and revealed the linkage, there was only only wrapped wire coming from the e-brake. When I cut open the wrap that was covering that small bundle, there only looked to be one wire...either red with black stripe or black with red stripe. I can't remember. But since I only saw one, I didn't bother running a voltmeter on it, I just assumed it was the right one. Guess I could be wrong.
*EDIT: There is only ONE wire I could find connected to the e-brake, and it was red with a black stripe. It connects to the button that the e-brake hits when it's in the 'down' position that I assume makes the light 'brake' light in the gauge cluster turn on and off. Is that the right one?
