bad igniter? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-09-2006, 05:57 AM   #1 (permalink)
View mktunes's Photo Gallery
Gen1 bad igniter?
my gen 1 engine was running fine, then 20 minutes of heavy spark knock under all but the lightest load, then the engine died and won't start---engine still turns over. replaced coil but still no spark out of the primary lead to the distributor. I'm thinking it's likely the iginiter, but wondered if the knock symptoms might indicate something else like ECU?
mktunes is offline   Reply With Quote
Old 05-14-2006, 01:37 PM   #2 (permalink)
mktunes
Replaced the igniter/coil assembly--- still not starting. Am I correct in thinking it is more likely to be the ECU than the pickup coils of the distributor? I'm not getting any spark coming out of the coil. Any help is greatly appreciated---thanks, mktunes
igniter troubles? fjkid Pre-88 Toyota Pickup/Hilux 3 04-12-2006 06:14 AM
Bad gas? ero2 2nd Generation (2005+) 9 10-12-2005 08:14 PM
2mz-Fe V6...Cam and Crank Seals...BAD ArmyofOne Camry & Solara Lounge 2 10-05-2004 10:27 PM
bad day with bad luck Dawgz Camry & Solara Lounge 20 09-18-2003 08:47 AM
