Wastegate or VSV problem?
So for some unknown reason i can't boost past 7psi. Just wondering if anyone ever had this problem...
This happens with the Turbo VSV electrical connection disonnected.
If I disable the wastegate completely (plugging both vacuum lines to wastegate) it boosts with no problem past 7psi.
If i plug the hose from the wastegate to the Turbo VSV i still can't get past 7psi.
Could it be something mechanical with the VSV? I was under the impression that the VSV is normally closed unless otherwise stated by the ECU. Or is it the other way around?
Any help would be appreciated!!!
