it moved - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-15-2006, 02:31 AM   #1 (permalink)
Gameroom cash: $134355
it moved
was running, waiting for thermostat to open...
and later:
drove it a couple blocks (no exhuast.... open header) and felt alright...
pretty stock (egr removed, JDM manifold, early bigport from an ae86, c50 from another mr2 owner)... new battery, new pads/rotors (all around), replaced the 2 lines to the clutch (soft & hard lines after the chasis) with a single SS braided line, cheap ebay coilovers (for a miata) bolted in.
Old 05-15-2006, 06:11 AM   #2 (permalink)
BrightTundra04's Avatar
View BrightTundra04's Photo Gallery
What yea Miata stuff did you use?? and was it a direct bolt in??
BrightTundra04 is offline   Reply With Quote
Old 05-16-2006, 02:20 AM   #3 (permalink)
early miata..... first gen
in those pics.... the rear is at full height and the front is fully lowered..... i need to get new struts, and when i do I will cut the perches off and have them welded 1-1.5" lower so i can utilize the coilovers
different cheap brands have different upper coilover perches.... this set just happened to have a set that the fronts sit differently (what do you expect for $40 shipped)
wtf? who moved everything? andyman61 Off Topic 27 08-12-2005 11:20 PM
post moved to audio video forum klaymen333 2nd Generation (2005+) 0 05-24-2005 08:56 PM
Need to get a thread moved toytruck86 Site Suggestions, Questions, and Comments 8 03-22-2005 09:04 PM
moved to KC, Missouri maggotdecay Off Topic 4 11-09-2004 12:01 PM
