91 oilpan and sunshade - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-16-2006, 09:27 AM   #1 (permalink)
AuroraGuy's Avatar
Location: Wisconsin - Smell the dairy-aire! - Have you hugged your cow today ?!
View AuroraGuy's Photo Gallery
I just bought a 91 and noticed the oil pan seems to be leaking pretty badly. This seems ez enough to change...anyone have any comments??
Also, I noticed I am missing the sunshade for my pop-up sun roof and was wondering if anyone has a good source for that..
-JD
AuroraGuy is offline   Reply With Quote
Old 05-16-2006, 11:01 AM   #2 (permalink)
View NU2MR2's Photo Gallery
When you do your oil pan you'll need gasket maker, cause I'm pretty sure there is no replacement gasket, and MAKE SURE YOU LOOK UP THE TORQUE SPECS!!! The specs are pretty light.
NU2MR2 is offline   Reply With Quote
Old 05-16-2006, 03:49 PM   #3 (permalink)
View Gairloch's Photo Gallery
^^ There is no factory gasket but there are cork gaskets available. Do NOT use the cork gasket, damn thing leaks like crazy.
x2 on make sure you look up the torque spec and use a torque wrench. The oil pan bolts only call for like 7 ft/lbs. I'd look it up but I'm stuck behind a firewall atm :/
"Our Lady of Blessed Acceleration, don't fail us now!" -Elwood Blues
Gairloch is offline   Reply With Quote
Old 05-16-2006, 07:21 PM   #4 (permalink)
Noob :-)
View ST185's Photo Gallery
The Toyota seal packing (gasket maker) part number is 08826-00080
Don't forget to scrape old gasket off and don't drop oil on the mating surface.
Torque is 4 ft-lbs (48 inch-lbs)
93 ST185
ST185 is offline   Reply With Quote
Old 05-16-2006, 07:26 PM   #5 (permalink)
AuroraGuy's Avatar
thanks for the replies guys. I appreciate it.
My kid works at a Toyota dealer so he is getting some of the parts I need a bit at a time.
This car is good but needs a few things...I just got wires/cap/roter, but dunno about plugs yet. I have run Iridium in my other Toyotas and very happy but not sure if there is a plug that works for this 91 (Non-turbo) engine.
It has been so long since I last drove an MR2....I think 89?
-JD
Old 05-18-2006, 12:57 AM   #6 (permalink)
^^ I just use NGK copper plugs in mine and change 'em every other oil change.
