OOPs, First thanks to all that took the time to think about what could be wrong with the tranny, but I figured it out after racking my brains and then I called a guy that does some tranny work and said the same thing that Fogjammer suggested. I knew that I did not bust the ears off of the pump but figured that the pump is just not working. So this evening I pulled the transmission out and checked the ears on the pump, still intact and looks OK. Then I started doing some inspecting and OOOPs, it appears that someone put the flex-plate on backwards. I feel like a nitwit but I guess that is what you get when you get in a hurry sometimes. Well I flipped it around and noticed that one of the flywheel bolts had a tread or two that did not look too good so I will try to pick a couple up tomorrow and start putting it back together. I should be getting pretty good at this. It only took about an hour and a half to get it out. So with the flywheel being on backwards when I tightened up the torque converter bolts it pulled the torque converter out of the pump ears and was not making any contact. Thanks again and I can see that I will be spending some time on this new-found site. Ron
