I just got my powerslot rotors (with gas veins) and they say to put them on in such a way that the bottom of the viens (closer to the hub) hit the brake pad first.
The reasoning behind this is (according to my logic, which is often flawed, so please dont base your setup off of this only) that the veins are for gasses that are created (most modern pads are engineered to not prduce gas)... so if the rotors are situatated the way i jsut decsribed, the bottom bites first, giving the gasses (if there are any) a chance to escape. Remember that the gasses can only exit via the outer rim of the rotor (at least on the rotors and pads i have, this is correct). This means that if they were situated the way RideMR2 describes, the gasses would be trapped in, or at least have an intrinsic inward motion, making it more pressurised (a bad thing) and would tend to push the pad away from the rotor.
My logic, again, but this is how i am putting my brakes on, if i dont post here ever again, put your rotors on the other way
