91 horn is haunted - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-18-2006, 06:37 PM   #1 (permalink)
AuroraGuy's Avatar
Location: Wisconsin - Smell the dairy-aire! - Have you hugged your cow today ?!
View AuroraGuy's Photo Gallery
91 horn is haunted
I have a 91 I just picked up and the horn/haz didnt work. Sure enough - no fuse!
so I put the fuse in and then listend to the horn sounding whenever it felt like it.
Get in the car -it blows
put the key in the ign - it blows
turn the corner -it blows
However when trying to hit the horn when needed..most of the time it fails.
Sometimes just breathing on the steering wheel is all it takes to get it to go!
So, I presume the horn switch within the steering wheel is bad. How hard is this to replace and has anyone done it -or- have the part number(s)?
thanks!
PS for now, the fuse is OUT
AuroraGuy is offline   Reply With Quote
Old 05-18-2006, 07:21 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998275
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
How irritating... sorry i don't have any helpfull info for you, but your thread was so funny... good luck on tracking down the problem..I'm sure you' figure it out..
The Jedi Speeder at CarDomain
Old 05-19-2006, 12:01 AM   #3 (permalink)
View Gairloch's Photo Gallery
You might want to check the horn relay. That circuit should only be closing when you hit the button on the wheel.
"Our Lady of Blessed Acceleration, don't fail us now!" -Elwood Blues
Gairloch is offline   Reply With Quote
Old 05-19-2006, 04:58 AM   #4 (permalink)
AuroraGuy's Avatar
Well I would agree...but based on how touchy the steering wheel is and is not, I have to think its within there.
Someone on here must have dealt with that before I am hoping
-JD
Old 05-19-2006, 02:32 PM   #5 (permalink)
AuroraGuy's Avatar
ok guys. I took off the airbag and found the 2 horn contacts.
they appear to be held in place by 2 T30 bolts on each side.
The top 2 bolts were almost ready to fall out
The bottom 2 bolts were snug as I would expect.
So...I was wondering if anyone knows if all (4) bolts should be the same..snugged and bottomed out. When they are, the contacts are not touching and things seem to work (untested at this time).
Although I think I found an issue, I cant imagine this actually causing my issue?
-JD
Old 05-19-2006, 04:37 PM   #6 (permalink)
View CompanyFlow's Photo Gallery
Doesnt hurt to try, unless you screw up with the airbag and break your nose.
CompanyFlow is offline   Reply With Quote
Old 05-22-2006, 03:39 PM   #7 (permalink)
-JD
I am behind a firewall and unfortunately can't look it up for you but you should be able to find the answer to your question in the BGB.
www.mr2-tech.com
Compilation: Programming Remote entry for GEN4 camry keithy 3rd & 4th Generation (1992–1996 & 1997–2001) 36 09-05-2009 11:54 AM
FS: 91 5sfe parts (cheap) mr2trd91 Car Parts for Sale 2 09-04-2007 01:52 AM
No horn / steering wheel basic electrical stilllearning6 Celica Forum 1 03-17-2005 07:38 AM
91 Mk2 Horn Switch Problem "Please help" johnr MR2 Forum 5 02-22-2005 12:05 PM
91 Tercel DX HORN piggyfinndude Tercel, Paseo, Starlet, and Sera Forum 1 08-25-2004 10:07 AM
