91 OEM tire pressures - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-19-2006, 05:12 PM   #1 (permalink)
AuroraGuy's Avatar
Location: Wisconsin - Smell the dairy-aire! - Have you hugged your cow today ?!
View AuroraGuy's Photo Gallery
I have a 91 with 14x6(195) and 14x7 (205) tires and the glove box sticker is all rubbed off.
Does anyone know the FACTORY recommended pressures for these tires or have a photo of the glovebox sticker they could post/send me?
I would like to have a valid sticker with numbers on it I can read!
-JD
AuroraGuy is offline   Reply With Quote
Old 05-22-2006, 03:50 PM   #2 (permalink)
View Gairloch's Photo Gallery
Factory recommended pressures is 32psi Front and 33psi rear.
As I'm sure you're aware, the ideal pressure can vary a bit depending on which tire you're running.
"Our Lady of Blessed Acceleration, don't fail us now!" -Elwood Blues
Gairloch is offline   Reply With Quote
Old 05-23-2006, 06:47 AM   #3 (permalink)
View vtsuckah's Photo Gallery
Yup, what he said. It varies.....I run 32 up front and 38 in the rear for my set up.
vtsuckah is offline   Reply With Quote
Old 05-23-2006, 03:35 PM   #4 (permalink)
^^ you don't find that much pressure in back causing your tires to crown some? I was running 35psi F/37psi R as an experiment for a track day and forgot to drop the pressures before I drove 600 miles home. I found the tire wasn't hitting evenly all the way across let alone allowing it to roll onto the shoulders properly.
Old 05-24-2006, 02:36 AM   #5 (permalink)
View 91MR2quickNA's Photo Gallery
You can use tire pressure to manipulate your understeer/oversteer. Anytime your front tires have more grip than the rears, you'll oversteer. So I don't recommend 38psi in the rear with 32psi up front.
Because of the rear weight on the tires, you can run up to about 36-38psi, which is needed during long high speed driving, while 35-37psi is needed up front for high speeds.
35psi front/34psi rear will give you just a hint of understeer, and I usually recommend that. If you find your front tires aren't gripping enough, just decrease pressure in 1 psi increments and test each setting to your liking.
Jason
2005 Tacoma D-Cab 4x4 Off-Road
1991 MR2 w/ ported 1MZFE (MZW20)
1991 MR2 N/A (SW21)
91MR2quickNA is offline   Reply With Quote
tire discussion for 07 camry CamryXLE07 5th & 6th Generation (2002-2006 & 2007-2011) 4 02-13-2012 12:25 AM
NEED 2006 Solara SE Sport Coupe V6 OEM Front Tire oxsekkie Solara 1 04-28-2006 02:18 PM
Front Tire Wear 91 Montanahelp 1st & 2nd Generation (1983–1986 & 1987-1991) 1 07-19-2005 12:16 PM
Winter Tire Update virtualkuz Archived Corolla threads 0 12-06-2004 12:24 PM
Pro Comp Tire Seperation Causes Crash Z71sc Feedback: Buyers, Sellers, and Vendors 0 10-19-2004 05:01 PM
