reliable clutchs?... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-22-2006, 09:54 PM   #1 (permalink)
View MKI_S/C's Photo Gallery
Gen1 reliable clutchs?...
what would be a go reliable clutch setup for my agze with stock tranny from my 88 na. i would like to find one for good hard launchs but not stiff and hard on the left leg
MKI_S/C is offline   Reply With Quote
Old 05-23-2006, 07:35 AM   #2 (permalink)
View clem's Photo Gallery
competition clucth
clem is offline   Reply With Quote
Old 05-23-2006, 12:35 PM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998275
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
an unsprung clutch will give you a good hard launch, but they aren't real great for everyday driving. There are several brands out there.I'm using an UNORTHODOX sprung windowed kevlar clutch and 8lb aluminum flywheel. rev's up quick! Unorthodox is pretty pricey. there are other good clutches out there for less...
The Jedi Speeder at CarDomain
Old 05-23-2006, 03:18 PM   #4 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
Talk to Josh @ www.Chicoraceworks.com about SPEC clutches.
Tell him I sent you. I've been buying all of my clutches throguh him.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 05-24-2006, 08:37 AM   #5 (permalink)
View keck03's Photo Gallery
i wouldnt recommend going too overboard with a performance clutch on a daily driver.
i have a spec stage 2 and it grabs awesome for track/autox. fine for regular driving but...
i commute down I95 to wash dc area each day. at most i drive it once a week on my commute. the stiffer clutch tends to get rather annoying when you are inching along in traffic.
i def would not get anything stiffer unless my power level needed it
keck03 is offline   Reply With Quote
Old 05-24-2006, 08:49 AM   #6 (permalink)
I love Cin
keck, are you saying your SPEC is stiffer than stock?!
I've had a stage 3 Spec, a stage 3/5 combo and a stage 5 (in there now) and they all have been easier on the leg than the stocker. They are even easier than my MK1
Old 05-24-2006, 10:37 AM   #7 (permalink)
Gen1
i have an 88 na an the pedal wasn't to stiff so i want that same feel
Old 05-24-2006, 12:31 PM   #8 (permalink)
Gameroom cash: $134355
try a TRD Japan PP with TRD Japan 3 puck clutch..... holy crap.... i literally get tired from driving it, and it grabs about, oh, 1/2" off the floor (after adjusting the pedal)
Old 05-25-2006, 07:50 AM   #9 (permalink)
Gen1
whats the deal with an E51 whats so special about it
Old 05-25-2006, 08:16 AM   #10 (permalink)
well to be honest i am not sure what the stock turbo clutch feels like. the spec clutch was done at the time of my swap. i can only compare it to my worn na one.
i guess part of it is i switch btwn that and my gs-r for my daily commute. the gs-r is still on its stock clutch at 74k miles (knock on wood). if i drive the mr2 for a couple of days in a row and then switch to the gs-r i notice a difference. its feels like i am driving an auto.
i guess i am just getting old.
seriously i have been driving manual for 10+ years and notice the clutch feel. its not that i am bashing it. it grabs at EVERY rpm i have tried launching at and thats what i got it for. its just for sitting in the parking lot that is 95 every day, i prefer something as light as possible. its so bad i even thought about buying an auto for the commute.
Old 05-25-2006, 09:23 AM   #11 (permalink)
BRAKE/STEER/THROTTLE
ToyotaTechGeek's Avatar
View ToyotaTechGeek's Photo Gallery
ok, i know everyone will chime-in about this clutch and that one...
i will say that the Toyota OEM clutch is spectacular! i've had one for over 3 years now. i launch the car, but i am NOT a drag racer-type. the car has seen track time. the car has done its fair share of autocrosses and such. so...
ToyotaTechGeek is offline   Reply With Quote
Old 05-25-2006, 09:24 AM   #12 (permalink)
heavy-duty trans will support a bunch of torque. it also is extraordinarily like the MkIIT trans and the ST165 transmissions. it's got an internal oil pump. and it's a VERY heav transmission.
Old 05-25-2006, 04:21 PM   #13 (permalink)
Boosting 15 psi :)
View Drifting Dane's Photo Gallery
I have a spec stage 3 and i was suprised to notice it was very streetable, but it also feels like the spec is just a bit heavier than stock (more pressure needed to depress the clutch).
It does make noise though... just a fair warning, the throwout bearing (at least according to my research) makes a ringing noise, and chatters a bit when engaging slowly.
Function over form.
Drifting Dane is offline   Reply With Quote
Old 05-25-2006, 06:00 PM   #14 (permalink)
140lbs....
speaking of which, i have an s/c clutch set for sale... it's in a TRD box, but i'm sure it's just an oem clutch since the only stampin is the Aisin stamp
Old 05-25-2006, 06:00 PM   #15 (permalink)
Gen1
so OEM should do the trick for my s/c
How reliable is www.rennenmotors.com?? Durrby General Discussion 1 05-12-2005 05:57 AM
How Reliable are toyotas??? fr0me0 General Discussion 96 02-26-2005 09:47 AM
Reliable comapny?? CamrySpeaksJL Feedback: Buyers, Sellers, and Vendors 1 12-10-2002 05:45 PM
Gen 3 Clutch's question~ Den 3rd & 4th Generation (1992–1996 & 1997–2001) 6 10-24-2002 07:57 AM
