Have to pump brake pedal sometimes? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-13-2006, 08:12 AM   #1 (permalink)
omg jdm
aaron7's Avatar
View aaron7's Photo Gallery
Sometimes when I push the brake pedal it doesn't seem to work till almost to the floor, so I release it and push it again; and it's fine. I've had the system bled twice... is it my master cylinder?
89 MR2 MK1.5 - endless project. shiny, check. fast... almost installed...
74 CB360 - Lots of cool cafe stuff
98 Jeep GC 5.9 - Mopar intake, Mopar ECU, H&R springs, a/d/s speakers & amps, 3 JL W3
aaron7 is offline   Reply With Quote
Old 06-13-2006, 11:26 AM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998275
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Your guess is prolly correct and most likely the master cylinder. If it is, other components like the brake cylinders aren't far behind.
When th fluid gets old or contaminated the result can be the same. You might wanna try and change the out fluid completely, bleed and see if that helps. but of course if it doesn't, you will have wasted all that fluid-unless you use a recovery container.
The Jedi Speeder at CarDomain
Old 06-13-2006, 11:29 AM   #3 (permalink)
omg jdm
aaron7's Avatar
How much is a master cylinder, and where can I get one at a good price?
Old 06-13-2006, 11:57 AM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
dunno...dealer, ebay, O'Riley's,Advance, PepBoys.. Just do some calling around and check prices. OEM is prolly best tho.
Old 06-13-2006, 01:17 PM   #5 (permalink)
omg jdm
aaron7's Avatar
Someone on mr2oc said that it might be the booster?
Old 06-13-2006, 03:27 PM   #6 (permalink)
Boosting 15 psi :)
View Drifting Dane's Photo Gallery
The Mk.II does have a brake booster, right behind the master cylinder.
Function over form.
Drifting Dane is offline   Reply With Quote
Old 06-13-2006, 03:45 PM   #7 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Ah ha! it sho does. I guess I nevere noticed cuz it's behind that plastic shroud. and I hahven't had any brake problems either. Thanks Dane!
Old 06-13-2006, 04:30 PM   #8 (permalink)
View Gairloch's Photo Gallery
It is very likely that it's the master cylinder.
"Our Lady of Blessed Acceleration, don't fail us now!" -Elwood Blues
Gairloch is offline   Reply With Quote
Brake Pedal Inconsistent Paul Mcmenamy MR2 Forum 0 04-14-2005 01:39 PM
Brake pedal goes to the floor when the car is on? brando Yaris, Vitz and Echo Forum 3 12-16-2004 10:27 PM
94 v6le ABS and brake trouble bronzemaxell 3rd & 4th Generation (1992–1996 & 1997–2001) 0 12-16-2004 07:08 AM
brake pedal problem lam_jai Camry & Solara Lounge 8 12-07-2004 11:15 PM
