Need new brakes... are these on ebay any good? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-13-2006, 08:37 AM   #1 (permalink)
omg jdm
aaron7's Avatar
View aaron7's Photo Gallery
I need all new brakes. I'm going to buy:
4 rotors
4 sets of pads
4 calipers
Stainless brake lines
I found these rotors on ebay:
http://cgi.ebay.com/ebaymotors/87-88...QQcmdZViewItem
Are they worth it? Sure are cheap...
If not, what rotors should I get?
What pads should I run?
Lastly, are these lines good?
http://www.jcwhitney.com/autoparts/I...18446610050173
89 MR2 MK1.5 - endless project. shiny, check. fast... almost installed...
74 CB360 - Lots of cool cafe stuff
98 Jeep GC 5.9 - Mopar intake, Mopar ECU, H&R springs, a/d/s speakers & amps, 3 JL W3
aaron7 is offline   Reply With Quote
Old 06-13-2006, 09:45 AM   #2 (permalink)
BRAKE/STEER/THROTTLE
ToyotaTechGeek's Avatar
View ToyotaTechGeek's Photo Gallery
i dunno. never heard of those. i would be weary.
ToyotaTechGeek is offline   Reply With Quote
Old 06-13-2006, 09:51 AM   #3 (permalink)
omg jdm
aaron7's Avatar
Probably just drilled OEMs. I have a pair of "magnum performance" cross drilled for the rear, but I can't get in touch with the company to get the matching fronts.
Old 06-13-2006, 03:30 PM   #4 (permalink)
Boosting 15 psi :)
View Drifting Dane's Photo Gallery
While i dont know about the ebay things, those Goodridge SS brake lines are some of the best, they have an outstanding reputation, in addition JC Whittney is a reputable store.
Function over form.
Drifting Dane is offline   Reply With Quote
Old 06-13-2006, 04:22 PM   #5 (permalink)
View Gairloch's Photo Gallery
Are your calipers beyond rebuild? You can get rebuild kits for all four corners for ~$50 total.
"Our Lady of Blessed Acceleration, don't fail us now!" -Elwood Blues
Gairloch is offline   Reply With Quote
Old 06-13-2006, 05:11 PM   #6 (permalink)
i think i remember someone saying something about the way the goodridge lines fit. i think i remember the russell lines being really good especially for the money.
Old 06-13-2006, 06:23 PM   #7 (permalink)
omg jdm
aaron7's Avatar
They all work, but I want new everything.
Old 06-13-2006, 07:23 PM   #8 (permalink)
Rebuilt calipers are pretty much as good as new. If you want 'em to look good you could pull all the rubber boots and stuff off and get 'em media blasted clean. Just a couple suggestions to save you some $$
Old 06-17-2006, 11:58 AM   #9 (permalink)
View todd0305's Photo Gallery
From what I've read and heard, crossed drilled rotors are mostly for looks because drilling the rotors cause it to lose integretiy of the whole rotor. Under severe braking the rotor can crack. The slotted brake rotors are better to use. The grooves are cut into the rotor but it still keeps it's integrity.
todd0305 is offline   Reply With Quote
Old 06-17-2006, 12:54 PM   #10 (permalink)
that is not necessarily true either. slotted rotors were created to vent gasses built-up under braking when organic pad compounds were used. they also 'cut' the glaze built-up under the heavy duress of braking in a race situation. the cross-drilled did the same thing, but didn't 'cut' the brake pads. you know, all of this talk of cracking...this is a debate that can and does go on forever. i have crossdrilled on the rears of my SC. i have not had a problem whatsoever. i use Metal Masters pads on the rear and i do have to heat them up in order to parlay the brake pads' ability to stop. i also have my brakes rear-balanced. yeah, it's a street car, not a purpose-built racecar, but believe that this car sees lots of threshold braking on a daily basis, autocross use, and the occassional romp on a road course.
Old 06-18-2006, 12:53 PM   #11 (permalink)
Thanks for clearing that up TOYOTATECHGEEK. I'm still reading up on them because I need replacements too.
1st issue with 07'Camry AESANTIAGO 5th & 6th Generation (2002-2006 & 2007-2011) 949 01-08-2008 02:49 PM
Good and Affordable subs cam2Xrunner Audio, Video, and Security - Tech 36 09-07-2007 09:14 AM
Very fine restaurant in Markham/Richmondhill? EKam Off Topic 38 02-08-2006 03:24 PM
Escaping death with good Brakes! Calvin327 Camry & Solara Lounge 12 04-04-2005 09:07 PM
Is this dash kit on ebay any good quality? DaSaiGoNDoN216 Camry & Solara Lounge 10 04-30-2002 06:40 PM
