power antenna - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-21-2006, 05:29 PM   #1 (permalink)
91T MR2
View compressor_guy's Photo Gallery
power antenna
Antenna goes up fine, but when it goes down, the motor keeps running. Is there a relay or a switch that can be replaced that is supposed to stop the motor?
thanks,
Jeff
compressor_guy is offline   Reply With Quote
Old 06-22-2006, 12:22 PM   #2 (permalink)
View semi-charmed's Photo Gallery
same problem i'm having right now...your gears are slipping inside the motor assembly
-Ryan
Project Turbo Two
semi-charmed is offline   Reply With Quote
Old 06-23-2006, 07:36 PM   #3 (permalink)
91T MR2
It doesn't sound like the slipping problem because it doesn't have any trouble going up or down. It just doesn't shut off right away after it's all the way down.
Old 06-24-2006, 04:54 PM   #4 (permalink)
View C12ESSIDA's Photo Gallery
i believe the only way that the motor could keep runing is if the teeth are striped or getting stripped. i guess i would look at getting a new mast for it im sure its around 60$
They have done studies you know. 60%of the time it works everytime. -=SEX PANTHER=-
C12ESSIDA is offline   Reply With Quote
Old 06-29-2006, 08:35 PM   #5 (permalink)
91T MR2
bought a new mast but it wasn't the problem.
found out that the plastic pin that holds one of the gears inside is broken.
Original Wires for Factory Power Antenna... JayMax03 Audio, Video, and Security - Tech 3 06-22-2006 01:02 AM
How Would I Be Able To Get The Most Power Out Of My Amp? Vato Loco Audio, Video, and Security - Tech 6 10-26-2004 02:22 PM
Power Antenna dna59 Camry & Solara Lounge 7 08-19-2004 09:22 PM
2000 4runner power antenna fred g 4Runner Lounge 3 01-07-2004 03:42 PM
