HKS blow off valve - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-23-2006, 09:46 AM   #1 (permalink)
MAX BOOST!!!!!!!
View mr2_dori's Photo Gallery
2nd Generation HKS blow off valve
hi, i have a question. i have the super sequentail bov and i keep hearing that this bov has to be tunned. is this true.
mr2_dori is offline   Reply With Quote
Old 06-23-2006, 10:32 AM   #2 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
how would you tune a BOV??..i have same one...just installed and using it....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 06-23-2006, 10:59 AM   #3 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
The one you have should not need anything done to it.
Most aftermekt BOVs are based on a spring design and it is possible that the spring tension would need to be adjusted.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 06-23-2006, 02:46 PM   #4 (permalink)
MAX BOOST!!!!!!!
because the sound i wanted was the butterfly or double chirp sound. im only getting that when i dont really get on the car. i would say around 3500 rpms and down it happens. is there a way that i can have it do it all the time.
Old 06-25-2006, 05:00 PM   #5 (permalink)
MAX BOOST!!!!!!!
2nd Generation
how do i adjust the spring on this bov if i can.
Old 06-26-2006, 07:25 AM   #6 (permalink)
View clem's Photo Gallery
theres a little spring on the back of it you`ll have to use a pliers and adjust it but if u dont adjust the spring right the car might stall every time u boost the car!
clem is offline   Reply With Quote
Old 06-27-2006, 02:09 AM   #7 (permalink)
Made with Real sour cream
View CentralPower's Photo Gallery
mr2_doribecause the sound i wanted was the butterfly or double chirp sound. im only getting that when i dont really get on the car. i would say around 3500 rpms and down it happens. is there a way that i can have it do it all the time.06-23-2006 11:59 AM
I know exactly what you're talking about, same reason I bought mine. The bad news is NO, you can't have that sound with a stock turbo set-up. And yes, you do have to adjust the spring pressure, I believe most stock 2's are like mine and end up being tightened most of the way down.
I've been told that the 'flutter' that sounds so cool is actually not a good thing. I've only noticed it on my ride when it was really cold out... A local friend of mine is running the HKS SSQ and gets the flutter every time on his RB20, bastard.
WANTED: Gen 3 3SGTE Igniter & resistor packs, MAP sensor, T-top shades (black), beat up strut bars (or cheap), Border vented C/F hood
FOR SALE:MR2/3SGTE - cams, fuel rail, 440's, flywheel, more: http://www.toyotanation.com/forum/sh...33#post1287233
CentralPower is offline   Reply With Quote
Old 06-27-2006, 09:45 AM   #8 (permalink)
MAX BOOST!!!!!!!
2nd Generation
so then there is no chance to get that sound all the time. and why is it bad for the car if it does do the chirp sound?
Old 06-27-2006, 01:05 PM   #9 (permalink)
BahaMR2
numbone's Avatar
View numbone's Photo Gallery
this butterfly effect or double churp u speak of does not just come from the BOV. this sound u want to accomplish is the sound of the turbo compressor surging. which is one of the purposes a bov is made to relieve from happening. this happens when your adjustment on the bov is too stiff for the current boost pressure so it does not release air properly.
i think your best bet of getting this sound is to recurculate a blitz BOV. but remember nuthin is really as good as the oem BPV or the SSQV II recurculated wont hurt.
1992 GT-S
numbone is offline   Reply With Quote
Old 06-28-2006, 04:28 PM   #10 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
I've noticed on my car the sound has a lot to do with the amount of boost being ran. When I'm on low boost... the blow off sound isn't too loud... when I'm running higher boost.... DAMN. I'm running a stock bpv recirculated.... still makes a good amount of noise.
Old 06-28-2006, 05:41 PM   #11 (permalink)
View Steve's Photo Gallery
I involuntarily managed to test a bunch of bovs and the ssq is probably the best that I know of for variable functionality and picky ecu's. Im not a huge fan of the noise but dont really have the option of a recirc.
blitz-leaks over 18psi unless you tighten the shit out of it then you get that cool flutter sound but thats bad
apexi-annoying and car stalled, unable to set for my application (uncirc)
turbosmart-excellent
turboxs-stuck after 2 weeks
I say stick with the HKS but set it to be functional, who cares about the noise
The best sound is the compressor surging. This is best accomplished if you run a straight pipe with no BOV.
But dont do it, your turbo will only last about 2 weeks
Steve is offline   Reply With Quote
Old 06-30-2006, 02:20 AM   #12 (permalink)
View CompanyFlow's Photo Gallery
Why does the turboxs BOV suck?
CompanyFlow is offline   Reply With Quote
Old 06-30-2006, 02:26 PM   #13 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998275
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
I've been running mine for over 2 years now. but everybodies engine is different. I haven't had any real problems...though I think it's responsible for the ocassional backfire...
The Jedi Speeder at CarDomain
1988 SC Blow off Valve Addon What one/how to 4-AGZE MR2 Forum 19 03-22-2005 08:16 AM
question about bov myRice MR2 Forum 23 12-01-2004 09:54 PM
HKS blow off valve hachi-rocu Supra Forum 3 07-29-2004 10:32 AM
