first race for my new mr2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-24-2006, 01:46 AM   #1 (permalink)
jdm 2nd gen ftw!
View nepopolus's Photo Gallery
ok my first real drag is coming up with a little rich boy who thinks his car is invinsible(05 gt auto with air intake and exhaust) now i have a jdm swap 2nd gen,intake,custom 3"downpipe and exhaust,ecu chips,and a 50 trim ct-26 and of corse manuel, i would think i already have him beat BUT just incase i am going to get a boost controller to go from 7 psi to 14 with these stats is there a dought i can loose?
o btw will my stock engine be fine on 14psi? the jdm motor had 40k on it
nepopolus is offline   Reply With Quote
Old 06-24-2006, 02:12 PM   #2 (permalink)
View clem's Photo Gallery
if i was you i would turn up the boost to 16psi with race fuel,the car will be fine.Jeff was well over 400hp on a stock motor with over 100,000 miles on it! The only thing u should need to work on is your reaction time and u will be fine!
clem is offline   Reply With Quote
Old 06-24-2006, 04:14 PM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998275
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
I don't know about the race fuel, but I would try to keep it around 15psi. anything above that would be safer to run a bigger IC. other than that your stock motor is fine.
are you talkin' 05 Mitsubishi GT?
anyway, don't over rev the engine. hit your optimum shift points. wind that 3rd and 4th gear.
let us know how this turns out--and be safe.
The Jedi Speeder at CarDomain
Old 06-24-2006, 05:41 PM   #4 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
Stock boost pressure is 11.8, if you are only getting 7 psi there is something wrong.
For some reason you are stuck in "safe boost."
I would not run over 15 psi with the stock turbo even with race gas and/or a better intercooler.
Nothing you do like that will change the inefficiency of the stock turbo over 15 psi.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 06-25-2006, 12:45 PM   #5 (permalink)
jdm 2nd gen ftw!
k tnx and the car is a mustang gt
Old 06-25-2006, 04:06 PM   #6 (permalink)
Gameroom cash: $134355
there is always doubt..... you could have engine/car problems or he could actually be a better driver than you.....
and in a 1/4 mile race, he has an advantage over you... since you have the possibility of mis-shifting
Old 06-26-2006, 03:34 PM   #7 (permalink)
BahaMR2
numbone's Avatar
View numbone's Photo Gallery
If You have a jdm 2nd gen swap i assume u also have the jdm ecu. this would explain your 7 pounds of boost due to standard low octane fuel. running 104 octane will allow the ecu to run 10 - 11 psi. 16psi with 104 octane would close the deal clem and i both use 104 with the JDM MR's when we know theres some guage pegging to be done.
1992 GT-S
numbone is offline   Reply With Quote
Old 06-27-2006, 09:53 AM   #8 (permalink)
MAX BOOST!!!!!!!
View mr2_dori's Photo Gallery
well i have a question then. i have a 3rd gen swap and my stock boost is like 8psi. if your saying that 2nd gens are stock 11.8 then whats is mine. is my stock boost that low because of the fuel i use too. and whats safe boost?
mr2_dori is offline   Reply With Quote
Old 06-27-2006, 10:37 AM   #9 (permalink)
I love Cin
You are a bit backwards on that.
The JDM cars have HIGHER octane fuel available which is why they put out MORE power and boost.
You should see at least 11.8 psi in any stock turbo MR2.
Old 06-27-2006, 11:18 AM   #10 (permalink)
MAX BOOST!!!!!!!
2nd Generation
so why is my 3rd gen at 8psi. if you are saying that its 11.8 on any mr2 turbo.
Old 06-27-2006, 11:27 AM   #11 (permalink)
I love Cin
Stock boost on a Gen3 is 13 psi and fuel cut was raised to 18 psi.
Why is your stock Gen3 running 8 psi?
Obviously because something is wrong.
My guess is that either the T-VSV is keeping you in low boost for some reason or your boost gauge is wrong.
Old 06-27-2006, 11:33 AM   #12 (permalink)
MAX BOOST!!!!!!!
2nd Generation
what is t-vsv? and how can i fix the problem?
Old 06-27-2006, 11:44 AM   #13 (permalink)
I love Cin
I'm not as famialir with the GenIIIs as I am the Gen 2s, but on the Gen 2s there is a T-VSV. That is a turbo vacuum switching valve.
Basically the wastegate is set up to open at 7 psi. As long as conditions are normal and healthy, the ECU opens the T-VSV to vent off some pressure so that you actually run 11.8 psi of boost. If the ECU senses things that it does't like, it limits boost to 7 psi by closing the T-VSV.
It will limit boost if ambient temps are too low, if coolant temps are too low and a few other situations. I'm not familiar with all of them. If you are not making full boost on a Gen3, I would talk to someone who is knowledgable about that specific engine.
Old 06-27-2006, 11:48 AM   #14 (permalink)
MAX BOOST!!!!!!!
ok thank you. you have been helpful.
Old 06-27-2006, 12:29 PM   #15 (permalink)
BahaMR2
numbone's Avatar
if its japanese ecu then you'll only see full stock boost pressure on high octane given that u havent upped the boost manually. if that fuel doesnt help jeff's point on the VSV is very probable. had the same problem with my car when first getting it.
1992 GT-S
FS: 1991 Super White Toyota MR2 Turbo! *Lots Of Pics!* [Cyanide] Vehicles 7 01-14-2006 11:27 AM
MR2 Safety Product Thread. =-) MR2 specific safety products from safedrives.com Safe Drives Supporting Vendor Sales 8 10-17-2005 06:16 PM
considering buying a mr2. bowlofturtle MR2 Forum 17 11-07-2004 12:44 AM
*** MR2 Club - FRIDAY, JULY 19, 2002 *** TRD2000GT Regional Meetings and Events 14 07-22-2002 10:28 PM
