seals can be damaged easily during installation. How bad is the leak? (I guess pretty bad if it's in the shop) If it's a constant drip while running (hot) you should try lucas tranny oil w/stop leak (or whatever they call it) it will help seat the seal. If you're sure it's from the seal area though and it's leaking badly, I'd check the axle & seal again.
WANTED: Gen 3 3SGTE Igniter & resistor packs, MAP sensor, T-top shades (black), beat up strut bars (or cheap), Border vented C/F hood
FOR SALE:MR2/3SGTE - cams, fuel rail, 440's, flywheel, more: http://www.toyotanation.com/forum/sh...33#post1287233
