'86 without factory air - How Many Fans? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-05-2006, 11:25 PM   #1 (permalink)
View gr8ful's Photo Gallery
Would an 86 w/o air conditioning have originally come with two radiator fans?
A friend's mr2 apparently had been in an accident before he purchased it - the fan assembly is a salvage part from an 85 and contains two radiator fan motors instead of an a/c fan motor and a radiator fan motor. Neither were working so my friend bought two new motors, $$$$$$$$. As it turns out, one of the old motors is in fact dead while the other one works fine when connected to the dead motor's wiring harness. .
So.......was his car originally equiped with two radiator fans and now one of the wiring harnesses is not getting power, or is the "dead" harness for an a/c fan that the car never had and not intended to power a second radiator fan?
Thanks for any assistance!
'94 Base standard cab, 2wd, 22R-E, 5sp, 2wd, 160k
gr8ful is offline   Reply With Quote
Old 07-06-2006, 08:44 AM   #2 (permalink)
View 91MR2quickNA's Photo Gallery
On the MKII, and pretty safe to assume for the MKI, the non-A/C car has only 1 radiator fan. You'll know for sure by looking at the relay box. Fan No. 2/Fan No. 3 are reserved for the A/C fan and A/C usage on the MKII. Fan Main/Fan No. 1 control the main cooling fan with input from the water temperature sensor.
Not sure if it's the same on the MKI.
Jason
2005 Tacoma D-Cab 4x4 Off-Road
1991 MR2 w/ ported 1MZFE (MZW20)
1991 MR2 N/A (SW21)
91MR2quickNA is offline   Reply With Quote
Old 07-06-2006, 09:03 AM   #3 (permalink)
omg jdm
aaron7's Avatar
View aaron7's Photo Gallery
Hmm, I have no idea! I have 3 MK1's... but all have AC. In fact, I don't know if I've ever seen a non-AC one!
89 MR2 MK1.5 - endless project. shiny, check. fast... almost installed...
74 CB360 - Lots of cool cafe stuff
98 Jeep GC 5.9 - Mopar intake, Mopar ECU, H&R springs, a/d/s speakers & amps, 3 JL W3
aaron7 is offline   Reply With Quote
Old 07-06-2006, 09:29 AM   #4 (permalink)
Neither had the parts guy at the dealer! I think it is pretty safe to say that whoever repaired the accident damage hadn't either. Thanks for your input. 91MR2quickNA, thanks for giving us a way to definatively answer the question!
What is starting to make sense is that the one motor burned up because the temp sensor is bad - when we swapped motors, the good one started immediately when the cold engine was started. At $200 a pop, I am glad the repair dude stored an extra motor in the fan assembly for future use!
I can't imagine there is much to replacing a sensor and that a sensor is cheaper than a motor! Either way, I imagine my friend would be better off ordering whatever he needs on-line rather than getting it from the dealer - best place to order a sensor?
Old 07-06-2006, 10:37 AM   #5 (permalink)
www.partznet.com
They always give you a discount on OEM Toyota parts. You might have to call and have them lookup the radiator water temp. sensor.
Jason
1991 MR2 N/A (SW21)
Old 07-07-2006, 02:28 PM   #6 (permalink)
RideMr2's Avatar
View RideMr2's Photo Gallery
Gen1 A/C Fan
I had three 86 models in the past, all 5 speeds.
One with no a/c, car came from MAINE.
One with no a/c has only one radiator fan.
91 MR2 5sfe
03 Grand Am 2.2L Ecotec
RideMr2 is offline   Reply With Quote
Old 07-09-2006, 05:27 PM   #7 (permalink)
mystery solved
The radiator fan is controlled by a temperature switch attached to the radiator. The a/c fan turns on whenever the a/c is turned on. The fan attached to the a/c wiring harness was still good because it never ran - no a/c. The radiator fan was dead because it was worked to death - the temperature sensor was bad and the default setting is "on". What I have determined, as others have said, an mk1 w/o air conditioning has only one fan. Thanks for all your input!
Old 07-11-2006, 03:27 PM   #8 (permalink)
Glad we could help.
Jason
1991 MR2 N/A (SW21)
Old 07-13-2006, 01:45 AM   #9 (permalink)
Gameroom cash: $134355
my 86 that had no factory (or dealer) installed AC has only 1 radiator fan and (obviously) no condensor....
my old 86 and current 87 both had AC and had 2 fans
For you Taka Aono Fans... his 86 flipping CamryPunk Archived Corolla threads 6 09-01-2005 11:19 AM
'95 AC Question Jevid Archived Corolla threads 0 08-30-2005 10:30 AM
'02 Tacoma AC Question shane28462 1st Generation (1995.5–2004) 0 07-10-2005 01:48 AM
fans not coming on mjjj44 Camry & Solara Lounge 4 03-04-2005 08:09 PM
MK3 TURBO!, No Heater, No AC, IM STUMPED!!! seiffert Supra Forum 0 04-24-2004 01:36 PM
