radiator temperature switch replacement damage - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-09-2006, 01:57 PM   #1 (permalink)
View gr8ful's Photo Gallery
Replaced the temperature switch on a mk1 with as little torque as possible but still managed to damage the radiator (caused a leak) near the thread for the switch. Might the radiator be repairable and is a flush at a radiator shop (radiator removed from car) a good idea?
'94 Base standard cab, 2wd, 22R-E, 5sp, 2wd, 160k
gr8ful is offline   Reply With Quote
Old 07-10-2006, 03:23 AM   #2 (permalink)
View toyomoho's Photo Gallery
Is the leak around the outside of the fitting where the sensor screws in? How much coolant is leaking? Is the cracked material plastic or metal? If the leak is small enough, it can most likely be repaired from the outside with the right glue. Check you auto parts store for radiator hole and crack sealants. You will need to drain the system, follow the directions on the sealant. The alternative is getting an opinion from a radiator shop, but the glues work pretty well. If the engine temp is OK now, just flush it yourself with water. I would not use any flushing compounds. Some of these just break any material inside the coolant system loose only to plug up the radiator tubes.
NEED HELP: Fan not working GetDFeelin Camry & Solara Lounge 2 09-15-2004 07:43 PM
Temp gauge relay [gen2] Zfreeman 1st & 2nd Generation (1983–1986 & 1987-1991) 9 08-21-2004 07:00 PM
radiator and ac fan not spinning rizzo Camry & Solara Lounge 6 05-11-2004 02:02 PM
Fuel and Temp meter not working Gen3 BoogieMan 3rd & 4th Generation (1992–1996 & 1997–2001) 7 07-05-2002 01:39 AM
