brake rotor turning Q? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-16-2006, 11:30 PM   #1 (permalink)
View jesse0880's Photo Gallery
are aftermarket drilled and sloted rotors ready to be put on right out of the box or do they need to be turned? i just recently changed all four corners and without thinking about it, i put them on my car anyway. they're BRANDI rotors if that helps. thanks.
jesse0880 is offline   Reply With Quote
Old 07-17-2006, 01:46 PM   #2 (permalink)
RideMr2's Avatar
View RideMr2's Photo Gallery
Ready to go out of the box, I don't think, but don't know if you can even turn drilled/slotted rotors.
How does the car stop?
91 MR2 5sfe
03 Grand Am 2.2L Ecotec
RideMr2 is offline   Reply With Quote
Old 07-17-2006, 05:14 PM   #3 (permalink)
3SGTE & 1GRFE
View NESW20's Photo Gallery
any brake rotor should be ready to go when you take it out of the box. just clean off the oily stuff on there and slap 'em on.
-Mike
1991 MR2 Turbo 2.1L stroker
2006 Tacoma D-cab 4x4 Auto TRD Off Road
NESW20 is offline   Reply With Quote
Old 07-17-2006, 10:46 PM   #4 (permalink)
thats what i thought, but like said earlier, I wans't sure if drilled and slotted rotors can be turned. thanks
Old 07-18-2006, 11:09 PM   #5 (permalink)
View toyomoho's Photo Gallery
The interrupted cut on a drilled or slotted rotor can cause the cutting bit to break. This may be the reason some shops shy away. If a light cut is made, this should not be a problem. But it takes more time to do the job.
94 Camry brake warning light eaglemtn 3rd & 4th Generation (1992–1996 & 1997–2001) 25 05-04-2012 11:57 AM
Are these good rotors to get? cman2000 Camry & Solara Lounge 32 11-24-2007 01:32 AM
Brake Pads will not clear Caliper wannawangan Camry & Solara Lounge 13 09-06-2005 03:06 PM
rav4 brake bleeding rav4jeff RAV4 Forum 1 12-26-2004 08:02 PM
Brake problems, trouble shooting, fix? itzsteven Camry & Solara Lounge 1 11-17-2004 04:50 PM
