Warning light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-20-2006, 07:04 AM   #1 (permalink)
View AndyL1960's Photo Gallery
Question Warning light
Hi, I have an Imported H reg N/A MR2, i have had the car for about a year now and have resently had a warning light come on, it looks like a square with a heatwave coming of the top of it. There is no mention of it in the manual i have? any ideas? thought it could be something to do with the cat... Also it seems to have a mmisfire or similar problem in hot weather, runs fine when the weather is cooler tho, any help would be appreciated.
AndyL1960 is offline   Reply With Quote
Old 07-20-2006, 12:01 PM   #2 (permalink)
BahaMR2
numbone's Avatar
View numbone's Photo Gallery
this symbol sounds like the fan failure light. check, fuse, relay. unplug engine temperature sender mounted on engine lid. unplug it. do yer fans come on?
1992 GT-S
numbone is offline   Reply With Quote
Old 07-20-2006, 01:03 PM   #3 (permalink)
I'm not sure if it is, as this light only seems to come on when i am doing hi speeds, would not have thought the fans would be used at those speeds. but thank you anyway.
2006 Camry: Fuel warning light kaikow 5th & 6th Generation (2002-2006 & 2007-2011) 18 08-17-2006 06:04 PM
Gen 1 - Gen 5.5 massive compile of bulb info ASG14 1st & 2nd Generation (1983–1986 & 1987-1991) 20 01-03-2006 03:51 PM
99 Camry Intermittent Brake Warning Light wpfloor Camry & Solara Lounge 8 09-22-2005 08:21 PM
Rear Wing Install - Inside warning light stays on. e32o Camry & Solara Lounge 14 06-13-2004 05:15 PM
