Gen3 engine begs for gen3 ECU/EMS, thoughts/help/advice? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-21-2006, 12:28 AM   #1 (permalink)
Made with Real sour cream
View CentralPower's Photo Gallery
3rd Generation Gen3 engine begs for gen3 ECU/EMS, thoughts/help/advice?
My gen3 runs on a gen2 ecu/afm. Before I catch flak, I didn't choose the setup, it was bought like this. Also proving it's strong is a 276rwhp dyno run.
As soon as I check compression I want to upgrade the rest of the car. This would be in the form of proper ECU and MAP. I have no experience or knowledge with an EMS but I'm sure someone here does.
Let me start by saying the power the car makes is very satisfactory to me. Does this mean an EMS would be kindof pointless to me/if I'm not looking for more power now/later? (I know I can add a turbo later without touching much else to hit the 320+ rwhp range, if I ever wanted more power that would definitely be the edge for me)
Cost is also a factor, I'm not interested in spending $1,000. I'm under the impression any EMS costs more than that but i am looking at good versus bad. I also do not have a laptop but I am lucky enough to have a dyno 10 minutes up the road. (I do have a home PC 5 feet from where the car sleeps)
As I know now, I need the gen3 ECU, MAP, 2 air temp sensors and at least an engine harness into ecu. (I'd like to replace the entire body harness too, the re-wiring into the ecu in the trunk is a mess)
As with everything I've done with the car, I want it reliable over all else. Any help or insight would be great! Thanks!
Mods are:
3" aussie DP & Blitz exh
Spearco I/C
Walbro HP FP
Apexi EBC
Apexi intake
HKS FCD
ECU will replace these: (happily)
AFM
Apexi SAFC
WANTED: Gen 3 3SGTE Igniter & resistor packs, MAP sensor, T-top shades (black), beat up strut bars (or cheap), Border vented C/F hood
FOR SALE:MR2/3SGTE - cams, fuel rail, 440's, flywheel, more: http://www.toyotanation.com/forum/sh...33#post1287233
CentralPower is offline   Reply With Quote
Old 07-21-2006, 07:19 AM   #2 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
you wouldn't happen to have the stock gen 3 oil catch can for sale??....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 07-21-2006, 10:59 AM   #3 (permalink)
Sorry, most everything I still have for sale is in the thread in my sig. Those oilcatch's are hot!
Now you owe me advice
Gen3 Engine Mounts? terrynham 3rd & 4th Generation (1992–1996 & 1997–2001) 22 06-13-2007 09:18 PM
Engine/ Car Specs gen3 Erbe 3rd & 4th Generation (1992–1996 & 1997–2001) 5 01-08-2005 07:58 AM
gen3 manual shifter problems.... engine mounts? jwa276 3rd & 4th Generation (1992–1996 & 1997–2001) 8 03-05-2003 08:33 PM
Gen3 engine swap out bigbodycam05 3rd & 4th Generation (1992–1996 & 1997–2001) 7 11-04-2002 12:20 AM
