Stalling - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-25-2006, 09:03 PM   #1 (permalink)
View lildaveyg's Photo Gallery
Gen1 Stalling
I just started having problems with my 85. After it warms up it idles rough and then once I'm going and de accelerate at a stop sign, it will stall. It will start right up but upon de acceleration it will stall.
Is it the fuel filter or something else?
lildaveyg is offline   Reply With Quote
Old 07-26-2006, 12:11 PM   #2 (permalink)
View FrankMeza's Photo Gallery
i've got an 86 and the same sort of thing was happening to me.... it could be a vacuum boot leak... lift up the hood and idle, and see if you cant hear any leakage
FrankMeza is offline   Reply With Quote
Old 07-26-2006, 06:35 PM   #3 (permalink)
Thanks,
I'll see what I can find.
Old 07-30-2006, 10:46 AM   #4 (permalink)
Gen1 I really need someone's help
I've checked for vacum leaks but have found none. I was about ready to change the EGR Valve when I discovered something really weird and maybe the problem.
While sitting in the car while it was idiling really rough and trying to figure out the stalling problem, I kept hearing a "clicking" noise. When I looked around I found that it was the A/C switch and the light would go from bright to almost off, along with the "clicking" noise and along with the RPM's dropping and then going back.
I decided to turn the A/C off. The idiling was perfect. I then took it for a drive. Whenever I had the A/C on, it would stall when I got to a stop sign. When I had the A/C off it was fine, no stalling.
Does the A/C work off a vacum and if not, what is causing this weird problem? I really need someone's help. [IMG]images/icons/gen1.gif[/IMG]
Strange Stalling Problem on 93 Camry 4cyl - Please Advise MSgtVac 3rd & 4th Generation (1992–1996 & 1997–2001) 35 11-02-2008 01:26 PM
1982 PU Cold Stalling Problem ripsnub Pre-88 Toyota Pickup/Hilux 4 02-04-2006 01:56 PM
stalling cold mcslow Archived Corolla threads 6 09-24-2005 05:11 PM
94 stalling camry Garvin021 3rd & 4th Generation (1992–1996 & 1997–2001) 0 04-20-2005 09:09 PM
Can a leaky/broken egr gasket cause stalling? Stealth Camry & Solara Lounge 5 04-19-2005 11:48 PM
