$2500 to turbo and tune my 20v... good? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-26-2006, 08:03 AM   #1 (permalink)
omg jdm
aaron7's Avatar
View aaron7's Photo Gallery
I was quoted $2500 parts/labor/tuning for my 20v MR2. This would be for a 8psi system I guess.
Is this a good price? I think I can afford it, and I really want this thing to be faster! I mean, the 20v swap did make a difference... but the car still isn't nearly as fast as it looks!
Also, what kind of power would 8psi make on a 20v with MegaSquirt, EDIS, intake, intercooler, etc?
89 MR2 MK1.5 - endless project. shiny, check. fast... almost installed...
74 CB360 - Lots of cool cafe stuff
98 Jeep GC 5.9 - Mopar intake, Mopar ECU, H&R springs, a/d/s speakers & amps, 3 JL W3
aaron7 is offline   Reply With Quote
Old 07-26-2006, 11:14 AM   #2 (permalink)
crazy wheels
mr2driver's Avatar
View mr2driver's Photo Gallery
i think 2500 is fair considering that most turbo kits run around there.
remember to go higher octane and colder plugs
i dont know how much power but i know a good rule of thumb for the 3sgte is 1lb=10hp and 14ftlb
mr2driver is offline   Reply With Quote
Old 07-26-2006, 11:22 AM   #3 (permalink)
omg jdm
aaron7's Avatar
Yah the guy told me I'd be looking at 200-225hp. Sounds good to me! haha
Old 07-26-2006, 01:26 PM   #4 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
1.5 mk1 would be nicer...3sgte swap...
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 07-26-2006, 01:36 PM   #5 (permalink)
omg jdm
aaron7's Avatar
ehhh the 3sgte is so passe tho. I mean, it's in MK2 MR2's and All-Tracs... and now people are putting them in MK1 MR2's. I like the turbo 20v idea because it is unique(r). Few people have one, and I just like the motor itself.
Plus... I already have one with the MegaSquirt all done, so that's half the battle :p
Old 07-27-2006, 08:10 AM   #6 (permalink)
crazy wheels
mr2driver's Avatar
did you dyno before the turbo install?
what compression are you running? isnt the 20v like 11:1?
Old 07-27-2006, 08:46 AM   #7 (permalink)
View keck03's Photo Gallery
what kind of turbo?
keck03 is offline   Reply With Quote
Old 07-27-2006, 08:46 AM   #8 (permalink)
omg jdm
aaron7's Avatar
No dyno yet, no. I plan to do it before I do the turbo.
Yes the 20v silvertop is 11:1, but it has the same internals (except the pistons) as the 4agze, so it is boost friendly. Just...not too much. I think you can do 8psi safely. I know a guy pusing 15psi on a stock internal one (in an MR2 no less) and he says he has no issues.
Old 07-27-2006, 08:47 AM   #9 (permalink)
omg jdm
aaron7's Avatar
Originally Posted by keck03
what kind of turbo?
No idea. I'm new to this world. I think he said... T23 or something?
Old 07-28-2006, 09:59 AM   #10 (permalink)
iirc the redtop sr20 had a t25 so i am guessing it is similiar but maybe smaller. if that is so it is a pretty small turbo but with that high compression i wouldnt go crazy.
i think you should do it but thats just my opinion. i would love to have a mk1 w/ a silvertop. then again i also want a 2zz-swapped mk3. now i just need my mk2 to stop breaking.....
Old 07-28-2006, 10:12 AM   #11 (permalink)
crazy wheels
mr2driver's Avatar
you should get a boost controller that lets you easily switch from a low safe boost to a haul ass boost.
just my thoughts
Old 07-28-2006, 10:16 AM   #12 (permalink)
omg jdm
aaron7's Avatar
Totally. I'll have it around 5psi daily driver, and 8psi or so for when those stupid ricers try and race me. Though I don't think I even need a turbo for most of them
Old 07-28-2006, 11:50 AM   #13 (permalink)
gLok's Avatar
View gLok's Photo Gallery
That sounds like a good deal as long as the kit is reliable and made well.
gLok is offline   Reply With Quote
Old 07-29-2006, 01:17 AM   #14 (permalink)
Gameroom cash: $134355
silvertops were 10.5:1 blacktops are 11.0:1
that being said... i'm curious as to who quoted you... i know that drtweak did your MS setup and if it's him doing the turbo, then it's probably been thought out well
otherwise, i would be a little skeptical..... i personally could do the whole setup (motor, MS/edis, turbo setup) for under 2500.... but that's because i always find stupid deals and can do the work myself..... that being said, for someone to locate the turbo parts (being that a 20V flange isn't exactly easily obtainable) and do the work for that much (a real shop usually charges $60 per hour for labor.....).....
anyways.... at the very least you'll still need larger injectors (the 290's on 20V's are too small for boost....) and the 20V's use sidefeed injectors.... which are less popular than top feeds... ie, more expensive and somewhat more difficult to locate.... you'll also need quite a bit of piping..... if you plan to keep the IC under the engine lid then you're gonna have to relocate the battery (or start cutting the engine lid... i did both on my 87 with the gze in it).... i would also reccomend a STRONGER plenum.... i couldn't see boost being held in that plenum too well......
Old 07-29-2006, 08:03 AM   #15 (permalink)
omg jdm
aaron7's Avatar
Yah it's the Dr.
Thanks for the info... I knew it was involved, but I didn't realize all that stuff!
How to Turbo the Camry - 5s-fTe tips and information Hamsterman Camry & Solara Lounge 118 09-23-2010 10:43 AM
5s-fe turbo install list R94CamryT Hardcore Tech and Competition 32 04-29-2009 01:37 AM
Twin charged ECU? Blazin674 Archived Corolla threads 30 04-11-2006 08:25 PM
where can i go dyno or tune my 89 turbo supra? Bibby Supra Forum 1 08-10-2005 06:27 PM
