worth it, or not?
so im looking at this 88 SC i've been putting together all week that i pulled from the junkyard with not one, but two rods done. white t-tops, needs a bit of body work, but still looks good and still solid. got 17" rims. just got a new set of eibach prokit springs this morning, along with and hks FCD and boost gauge. 240$ for all 3. i also have an hks turbo timer which im pretty sure is going on, was saving it for another car.
i put an ae101 4AGZE in, mostly stock replacement, i wanna drive it NOW. having some problems with the vacuum lines, need a throttle cable, new gromet for one of the shifter cables, some small things like that left.
i put an NST 180mm crank pulley on, used the timing belt tensioner off the old engine for a smaller tensioner. anyway, wondering if the FCD would help me at all in this car? if anyone knows, dont really wanna spend time putting it in for nothing. i've got more time than money wrapped up in this thing, just looking for an opinion. im also considering a tweak for the maf sensor i was reading, gonna put stright pipe instead of the cat once it passes e-test
