can i get some facts about the aw11? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-30-2006, 11:04 AM   #1 (permalink)
Sexy Run
AE92_GTS88's Avatar
View AE92_GTS88's Photo Gallery
hi i was thinking about getting an aw11 but im having second thoughts about the engine bay space, ive been hearing plenty of facts on how long it took to change the alternator, and oil filters due to the tight spaces. can i see some engine bay shots if anyone here has any?
thanks
AE92_GTS88 is offline   Reply With Quote
Old 07-31-2006, 08:22 AM   #2 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
The AW11 are not a problem for either oil changes or alternator changes.
I haven't found MR2s to be any worse than any other car to work on.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 07-31-2006, 10:06 PM   #3 (permalink)
Gameroom cash: $134355
to compare it to an ae92 gts....
as for oil changes.... they're usually easier, actually..... the aw11's seem to have more space between the filter and the firewall compared to an ae92's filter and radiator (if both cars have the same options then everything else is the same... IE a/c compressor is in the way.... however no PS pump like the ae92's)
as for alternators..... in an aw11 they can be a bit trickier than an ae92.... my FIRST aw11 alternator that i did i couldn't find an easy way to get the alt out, so i pulled some suspenion parts.... no big deal, only took an extra 15 min or so..... but if you look more carefully there's easier ways to get them out
but again, as for space they're about the same as an ae92..... ae92's seem to have a lot more enginebay space because the room in FRONT of the radiator is huge.....
Old 07-31-2006, 11:53 PM   #4 (permalink)
booN
View 86AW11's Photo Gallery
naw!... alt and oil filters are easy to replace. definitely not a reason to decide against the AW. i sourced oil cooler sandwich plates from a AE92(if i remember correctly) and it put the oil filter closer to the block and a little further away from the exhaust manifold.
'05 taco access cab 2wd 5spd 2.7
86AW11 is offline   Reply With Quote
Old 08-01-2006, 06:13 AM   #5 (permalink)
BrightTundra04's Avatar
View BrightTundra04's Photo Gallery
when i changed my alt i just removed the intake tube and pulled it ou through there. changinging the oild i use a screw driver to punch a hole and start the turn then spin it out by hand I'll have to see how hard it is to get out this time with just putting it on with my hand. The most fun thing to replace on these as far as bolt on parts goes is the starter but even thats not bad after reading how others have done it on here.
BrightTundra04 is offline   Reply With Quote
Old 08-01-2006, 06:34 PM   #6 (permalink)
i wouldn't reccommend using something that goes through the oil filter.... if they're tight enough, you WILL tear the filter in 1/2.... which makes the job that much tougher
for the person who was asking specifically is how i was replying.... seeing how i have (more) experience with both (see my sig....)
Old 08-01-2006, 10:46 PM   #7 (permalink)
Sexy Run
AE92_GTS88's Avatar
any engine bay shots? the last time i saw one was when i was 4.
Old 08-02-2006, 12:25 AM   #8 (permalink)
View Red October's Photo Gallery
Alternator is peachy easy. Mine was hard because the car had been abused, but it's less than a day's project if nothing has been molested. Pull the coolant tank (come out by hand, no tools) undo a bolt. Slip a belt off. Get under the car (ramps, jacks W/STANDS, however you can) undo another bolt. Undo some wires, slip it out, Drop in the new one and reverse the process. The last guy did an improper install on mine. Yay. About two days straight labor to fix. Now it's done.
There are only two kinds of service on an MR2:
a) "God that was easy!"
b) "Why the hell did I ever get involved with this stupid little car?!?!?!"
The only time I "Asked someone about their Toyota", I ended up owning it.
Red October is offline   Reply With Quote
Old 08-02-2006, 12:51 AM   #9 (permalink)
View mgd_only's Photo Gallery
well live pulled my engine out to put a 3sgte in but i believe i have one or two pics
here we go
http://http://s59.photobucket.com/al...Anch=imgAnch18
http://http://i59.photobucket.com/al...y/IMG_1635.jpg
and an empty bay shot just in case the swap bug bites
http://http://i59.photobucket.com/al...y/IMG_1666.jpg
mgd_only is offline   Reply With Quote
Old 08-03-2006, 09:19 PM   #10 (permalink)
Sexy Run
AE92_GTS88's Avatar
Thanks a lot for the info everyone nice car btw mgd_only.
jDm tOIt AIIIIGHT!
Jesus I suck . I apologize for this.
Old 08-04-2006, 09:41 AM   #11 (permalink)
lol thanks heres a pick of it before i got twobrutal
Old 08-04-2006, 03:46 PM   #12 (permalink)
booN
engine bay looks a little deceiving from above, it actually widens out below. most FWDs have less room around the engine then the AW.
Old 08-04-2006, 04:23 PM   #13 (permalink)
yeah it does widen closer to the ground but its also got everything that comes into the bay really organized to like all the fuel brake coolent lines enter in the same area as with the wireing save for the ecu in the trunks wires
Old 08-05-2006, 01:00 AM   #14 (permalink)
Sexy Run
AE92_GTS88's Avatar
hmm my ae92 has a lot of space problems like where the alt. is. eww its so cramped! and putting back the dipstick is a pain in the ass! lol its so frustrating! but ill eventually buy an aw11 in a few months, hmm my neighbor might sell his... ill see
jDm tOIt AIIIIGHT!
Old 08-07-2006, 01:59 PM   #15 (permalink)
omg jdm
aaron7's Avatar
View aaron7's Photo Gallery
All I gotta say is... start doing hamstring stretches!!
89 MR2 MK1.5 - endless project. shiny, check. fast... almost installed...
74 CB360 - Lots of cool cafe stuff
98 Jeep GC 5.9 - Mopar intake, Mopar ECU, H&R springs, a/d/s speakers & amps, 3 JL W3
aaron7 is offline   Reply With Quote
Oil changes & warranty..Facts? xsacta 2nd Generation (2005+) 13 07-24-2006 11:58 PM
Soon to be in a aw11 RSZero1 Introduce Yourself Here 0 10-25-2005 06:49 PM
New AW11 owner... ah_long MR2 Forum 8 10-26-2004 01:44 PM
Need URGENT attention Please!! AW11 spring question 20ValveMR2 MR2 Forum 0 08-26-2004 03:38 AM
