redtop highcomp ECU ?s - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-01-2006, 12:02 AM   #1 (permalink)
booN
View 86AW11's Photo Gallery
anyone know if the redtop highcomp ECU is a direct fit to '86 AW wire harness. running a redtop now with the OE blue top ECU. not sure if i will need to change over to a MAP sensor? anything help is greatly appreciated!
'05 taco access cab 2wd 5spd 2.7
86AW11 is offline   Reply With Quote
Old 08-01-2006, 06:35 PM   #2 (permalink)
Gameroom cash: $134355
i would not see any reason why they would be the same....
the aw11's use injector resistor boxes and the ecu has a hand in TVIS.... neither of which smallports use... i doubt the pinouts are even the same
Old 08-04-2006, 04:02 PM   #3 (permalink)
booN
done the redtop swap but thinking the ECU is mapped differently. everything still works fine but was hoping to get a few more HPs out of her.
4AGE ECU Reset & Teach REN69 Archived Corolla threads 24 10-28-2011 04:58 AM
The Free Mod Series - Part IV Cheaply Monitoring the ECU & A/F Toysrme Camry & Solara Lounge 10 08-16-2009 09:54 PM
Asap!! Haynes Book Bites-need Schem.of 91`22re Ecu Wire`n Diagram-2 Plug Ecu Not 3 charrliy525 Pre-88 Toyota Pickup/Hilux 0 05-19-2006 10:53 PM
