Fastest MR2 engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-05-2006, 12:47 AM   #1 (permalink)
View streetnasty's Photo Gallery
Japan Fastest MR2 engine
I was wondering what the fastest MR2 engine is. What are all the specs for it too? thanks i really need the help im doing an engine swap and i need to choose an engine.
ken
streetnasty is offline   Reply With Quote
Old 08-05-2006, 03:35 AM   #2 (permalink)
View Red October's Photo Gallery
Fastest? As in highest achievable RMP? Or do you mean highest Horsepower? I assume you mean which will make your car fastest. I believe the answer to that is the hyper-rare twincharged engine which I believe could make upwards of 400 HP. Not many of them were made. There was also a twin-turbo MKI that was slightly lesser but still mind-blowing.
Easily available MR2 engine with the most powered I believe is the 4AGZE with 145 HP. This is the most powerful engine an MR2 ever mounted. There are variants of the 4AGZE floating around, specifically in the JDM versions of the otherwise unremarkable Corolla, which reached 170 HP, which is probably the most powerful engine you can easily mount in an MR2 but good luck getting hold of one. Also there are 20-valve versions of the 4AGE which nearly meat that figgure at 165 HP.
But all sorts of engines can be fitted, I've even heard tell of Cadillac V8s crammed into MR2s. Yes, you need a BIG shoehorn.
The only time I "Asked someone about their Toyota", I ended up owning it.
Red October is offline   Reply With Quote
Old 08-05-2006, 05:42 AM   #3 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
Fast refers to "speed."
That begin said, the fastest engine an MR2 has been the 3SGTE.
It has gone 218 mph:
http://www.mr2ownersclub.com/mr2records/mr2records.htm
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 08-15-2006, 07:28 PM   #4 (permalink)
View Gairloch's Photo Gallery
^^ *to date* I would be willing that a v6 matched with the right tranny could break that.
"Our Lady of Blessed Acceleration, don't fail us now!" -Elwood Blues
Gairloch is offline   Reply With Quote
Old 08-16-2006, 01:24 AM   #5 (permalink)
True, but how far do you want to go in that direction; someone put a pair of General Electric Jet engines on his MKII and got it up to "187 MPH with a lot more room to go."? And nobody ever mentioned what car this guy has; a MKI or a MKII. As a MKI owner I naturally assume a MKI, but I have no idea.
Old 08-16-2006, 04:38 AM   #6 (permalink)
I love Cin
The original poster asked about the "fastest MR2 engine,"
not the fastest engine that could be put into an MR2.
There is no MR2 V6 engine. Yes, there are MR2s that have had V6s (And even V8s) stuffed into them, but they are still not "MR2 engines."
You know what they say about "assumptions."
If you would look at the link I supplied above, you would see the MR2 with the jet engines.
There is a video as well ... and it is not a MK1.
Old 08-16-2006, 03:46 PM   #7 (permalink)
That's not how I read the post.
Originally Posted by streetnasty
...... thanks i really need the help im doing an engine swap and i need to choose an engine.
I wasn't meaning to argue with you. Just throw out another possibility.
Old 08-16-2006, 08:41 PM   #8 (permalink)
I love Cin
... it's all good, we all read and 'hear' things differently.
If you had to answer his question based soley on the thread title, what would you say
Old 09-17-2006, 09:52 PM   #9 (permalink)
View locivar's Photo Gallery
hey wwait a min
isnt the mr2 spyder considered an MR2? the spyder has a v-6 turbo'd engine.
locivar is offline   Reply With Quote
Old 09-17-2006, 10:24 PM   #10 (permalink)
In love with boost
emiliorescigno's Avatar
View emiliorescigno's Photo Gallery
The MR2 Spyder had a 1.8L 4-banger, the 1ZZ-FE. Put out 130hp.
emiliorescigno is offline   Reply With Quote
Old 09-18-2006, 11:28 AM   #11 (permalink)
MAX BOOST!!!!!!!
View mr2_dori's Photo Gallery
2nd Generation
its the 3rd gen 3sgte. or 3sgte in general. no one can argue that.
mr2_dori is offline   Reply With Quote
Old 09-18-2006, 04:00 PM   #12 (permalink)
That Acura Guy
TTercel's Avatar
Gameroom cash: $267565
View TTercel's Photo Gallery
I have to say aint it stupid thats the MRS got the 1ZZ, what was Toyota thinking when they dropped that motor into the MRS. They should have kept the 3SGTE motor into it.
TTercel is offline   Reply With Quote
Old 09-18-2006, 05:53 PM   #13 (permalink)
MAX BOOST!!!!!!!
i think that toyota was building the mrs more for handling than power. but i heard that if you swap the 2zz in it, that car is even better.
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 11:48 AM
Very interesting... NH05TACOMA 2nd Generation (2005+) 52 04-08-2008 06:20 PM
1991 Toyota MR2 Turbo - What is considered bad,good,excellent engine compression? BolderMR2 MR2 Forum 1 07-28-2005 05:00 AM
Put 1993 mr2 engine into Honda crx jdmracer MR2 Forum 63 09-30-2004 12:15 PM
87 mr2 n/a question (4age engine) mr.2ner Hardcore Tech and Competition 1 12-31-2002 03:34 PM
