EGR VAlve - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-13-2006, 10:03 AM   #1 (permalink)
What' Cone?
MR2 Shadow's Avatar
View MR2 Shadow's Photo Gallery
Gen1 EGR VAlve
I have an '87 MKI NA that has a bad EGR valve. I have been told to just remove it. The car is all original except wheels and suspention. Does any one what the valve costs and how hard is it fo me to replace it?
MR2 Shadow is offline   Reply With Quote
Old 08-15-2006, 06:55 PM   #2 (permalink)
View dwebb99's Photo Gallery
The valve is very easy to remove. Dealer has part, or check aftermarket suppliers. A Haynes manual I beleive gives steps to check to see if it is defective. On high mileage MK1's it is not uncommon for the EGR pipe to be clogged(carbon deposites) at the point that it is bolted to the intake manifold. Simply remove said egr pipe and clean. EGR system recirculates exhaust gases back into the engine via the intake. Many emmision testing places require you EGR system. Clean it yourself and check working condition. Very easy DIY project.
dwebb99 is offline   Reply With Quote
2000 Solara check engine light mytoyota02 Solara 25 10-16-2011 12:06 PM
EGR valve '96 ES BobES300 General Lexus Discussion 0 11-16-2005 08:44 AM
1990 Camry 3sfe EGR valve Kep 1st & 2nd Generation (1983–1986 & 1987-1991) 0 08-29-2005 10:33 AM
egr valve replacement write up TheRyanator Camry & Solara Lounge 2 12-14-2004 09:07 AM
EGR Valve _VVTi_ Camry & Solara Lounge 21 10-11-2004 10:35 AM
