got fuel and spark but its still a no go! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-17-2006, 06:35 PM   #1 (permalink)
View celeritas's Photo Gallery
Gen1 got fuel and spark but its still a no go!
heya guys , i just recently replaced the blown motor in my aw11 mr2 with another 4ag out of my previous one that my brother rolled . everything swaped in beautifully after replacing parts of the chassis harness i thought everything would be sweet and ide be driving it to school within the week . i finally got it to turn over and its getting power to the coil ...its getting spark ...and i checked the lines that go to the fuel rail and it getting gas but it still wont start!!! i also checked that the ECU was getting power and i checked my fuses ...i dont know anymore . i doubt its timing since i timed the engine 2 days b4 my lil bro rolled the older car....ahh...it ran great ....but ya ...if u guys have ANY clue ...please help..im tired of taking the bus ...i hope its something really obvious .
celeritas is offline   Reply With Quote
Old 08-23-2006, 01:34 PM   #2 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
doesn't start is pretty vague.... wha kinda of no start?
no crank?
cranks but doesn't start?
start but doesn't run?
runs the dies?
did u just swap the motor.... or ecu? harness?
best thing is to assume no one is perfect and you made a mistake somewhere.
as a tech number one problem i find is human error.
tHa kNiGHt FaLL is offline   Reply With Quote
Old 08-24-2006, 03:31 PM   #3 (permalink)
Danno
View 89yotarollagts's Photo Gallery
ive had simialr issues hows the Cap & rotor on the distributor ?
"True car enthusiasts are open-minded to everyone's creation"
"Straight Roads are for Fast cars... Curvy Roads are for Fast drivers "
89yotarollagts is offline   Reply With Quote
Old 08-24-2006, 07:58 PM   #4 (permalink)
3SGTE & 1GRFE
View NESW20's Photo Gallery
did you pull a plug wire to make sure it's getting spark at the end of the wire? does it fire at all? do you hear pops out of the exhaust?
-Mike
1991 MR2 Turbo 2.1L stroker
2006 Tacoma D-cab 4x4 Auto TRD Off Road
NESW20 is offline   Reply With Quote
Old 08-25-2006, 08:31 PM   #5 (permalink)
Gameroom cash: $134355
if you pulled the distributor out then put it back in there's a decent chance the timing is off (off by the teeth on the distributor)....
easiest way to check is to pull the exhaust cam cover and then set the motor at TDC for #1.... the mark should line up on the dizzy....
Old 09-09-2006, 12:36 PM   #6 (permalink)
The motor cranks over fine ...im getting spark and fuel up to the rail i started the motor while it was in the old car the day before i did the swap. and it ran fine. unless i screwed up the timing while doing the swap i think its ok ...i bet its a wiring issue... :sigh:
93 camry, spark fuel, timing all god but no fire. Help! SSC 3rd & 4th Generation (1992–1996 & 1997–2001) 1 10-31-2006 11:14 AM
"Your Mileage May Differ" musubi 2nd Generation (2005+) 10 06-22-2006 02:56 PM
"Engine Won't Run" GUIDE! FOR THOSE W/ ENGINE PROBLEMS DallasToyo Camry & Solara Lounge 3 01-21-2006 01:04 PM
help newbie save '85 with fuel system problem leiniesred MR2 Forum 0 02-28-2005 09:49 PM
