FUEL PUMP REMOVAL = h377 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-21-2006, 12:51 AM   #1 (permalink)
View B-RADMKIIMR287's Photo Gallery
2nd Generation FUEL PUMP REMOVAL = h377
so im trying to trouble shoot a problem.....
ive got my 87 mk2 turnin over but no go....
starters good batterys good fuses good cpu is good filter pump and injectors are questionable and ideason getting it running?
B-RADMKIIMR287 is offline   Reply With Quote
Old 08-21-2006, 03:14 PM   #2 (permalink)
USA wow it runs
so i replaced the fuel pump and now i have acceleration problems.....any ideas?
Old 08-21-2006, 11:13 PM   #3 (permalink)
kthxbye
lol, MR-2's Avatar
View lol, MR-2's Photo Gallery
Gen1 h311
Yeah, the trouble of replacing the fuel pump is large without a lift. My 86 also has acceleration problems and we can't figure out why.
lol, MR-2 is offline   Reply With Quote
Old 08-22-2006, 01:58 AM   #4 (permalink)
View Red October's Photo Gallery
Try filter first. It can be done in theory from the top and in practice with the car backed onto ramps. Surprisingly MKIs will BACK onto ramps, which is convenient as that is where the motor is. You do not even need sportscar ramps to back it, regular ones will do. Give it a shot. I did one with a car jacked and lowered onto blocks (Solid blocks!). Here's a hint: Don't change the fuel pump after a marathon session of trying to get the bloody thing to turn over. Pull the Fuel pump fuse and crank the living shit out of it for a while to clear the lines, otherwise you'll end up covered in fuel (like I did) and all you need is one spark to end up like the cover of a certain Pink Floyd album (like I thankfully did not), and I DON'T mean covered in lightbulbs.
Oh, and an 87 is a MKI, not a MKII.
MKI-1983-1989, MKII 1991-1999. The 1990 MR2s are someplace running races against the 1983 Corvettes.*
*Actually there ARE some 50-odd 1983 Corvettes extant. They were made as test vehicles and released to GM engineers and execs for evaluation. It was determined to be a good car, but not good enough, so it was refined some more and released 6 months late as the legendary 1984 Corvette. I do not believe there are any cars that can rightly be considered 1990 MR2s.
The only time I "Asked someone about their Toyota", I ended up owning it.
Red October is offline   Reply With Quote
1988 wagon fuel pump removal Montanahelp 1st & 2nd Generation (1983–1986 & 1987-1991) 2 02-27-2005 10:00 PM
Fuel pump requirements for 5psi boost (carb'd 4a-c)? O 16581 72452 5 Archived Corolla threads 4 03-17-2004 12:00 PM
