It's been a very long and winding path, but I am finally done.
... done modifying Hyde that is.
I realized back in May that the only thing I really, truly wanted more out of Hyde is larger rims and tires ... and that would require coilovers as there is no way to get bigger tire up front with the stock suspension.
It's my only gripe with building an MR2 to the level that I have. You just can't get really big tires on the car. The RX7 that runs the hills with us has a 285/18 stuffed up front!
Unfortunately, SpyderVenom (Rob) on MR2OC.com contacted me a few weeks ago and told me that he was going to be parting out his insane SM2 turbo MR2. I talked to several times in the past about his set up as he is the only person I knew running the tire configuration that I wanted to stuff under Hyde. Obviously he knew I would be interested.
Last night I made the trip to Philly to pick up everything (what a load!) and tonight I started hitting Hyde with a hammer (literally) to get the front tires to fit under the car
This is what I picked up from Rob:
Tein HT coilovers - independently adj. compression (x16) and rebound (x16)
Tein Springs (224 lb F and 500 lb R)
Tein Camber Plates
One set of rims & tires:
17x8” front w/245 Kumho V710
17x9” rear w/275 Kumho V710
Second set of rims & tires:
17x8” front w/245 Kumho V700 Victoracers
17x9” rear w/275 Kumho V700 Victoracers
There was another full set of the V700s that Rob beat on for 2 seasons.
He also threw in his 2 front fenders that he "radiused" in order to fit the front tires.
David Hawkins & I are doing the complete install Thursday night.
Over the winter I will pop the fenders off, have them radiused another 1/4" or so, have them finished and painted black ... Hyde is getting more and more black every year.
We should be out autocrossing this new set this Sunday.
I truly loved the way I had my suspension set up, except for autocrossing,
and I hope it does not take me too long to get comfortable with this set up.
I am really. really excited about finally getting huge tires all around. The down side is these weigh considerably more. I haven't actually weighed them yet, but the rims are bigger and the tires are much bigger, so there is plenty of weight being added ... such is life.
I really want to give a huge thanks to Rob & SpiralMoons (Cin) for making this possible. Rob, it killed me to see your car apart last night
, but I'm sure your next project will be a great one. Good luck with everything.
Some photos ...
The Tein system:
The 2 sets of rims & 3 sets of tires: (the standing tire is one of Hyde's old rears)
The 'new fronts' (245/17 w/V710) vs the 'old fronts' (Kosei K1 15X7 w/a 225/45/15 Kumho V700:
The wheels & tires as they were on Rob's car:
