cluster and swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-29-2006, 08:10 AM   #1 (permalink)
View RedMK's Photo Gallery
cluster and swap
i am trying to install a JDM cluster, is it plug and play? i have 91 turbo..
also, do all of your sw20s burn oil? mine is burning like crazy..
what is the average cost for swapping a 2nd to 3rd??
including parts and labor.. thanks
RedMK is offline   Reply With Quote
Old 08-29-2006, 08:23 AM   #2 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
Is your cluster also from a '91 or is it from a '93+? Your car will have a mechanical speedo... where the '93+ will have an electronic one. Other than that it should be pretty strait forward.
No your car shouldn't burn oil. Where is the oil coming from?
A good clean swap should run you between $3k - $4k for everything. Depending on what bells and whistles you want. Plus since you already have a turbo you can sell a lot of the leftover parts off.... even your old engine.
Old 08-29-2006, 10:35 AM   #3 (permalink)
View mgd_only's Photo Gallery
redmk if your getting rid of your emissions stuff when you do your swap i would be willing to buy it from you
mgd_only is offline   Reply With Quote
Old 09-04-2006, 09:41 AM   #4 (permalink)
the cluster is whatever cluster i see on ebay.. not sure year are they.. so if its a 93+ then it won't just plug and play.. what do i have to do to make it plug and play? swap an engine that is 93+???
i am not sure where is the oil burning from. about 2000 miles after oil change my oil light will keep on turning on for low oil... so i had to put in some oil.. especially now i use syntenic oil.. that ain't cheap...
a good cheap swap should cost me anywhere from 3k to 4k including the engine too??? that's pretty nice.. are you sure? any body know a good shop in MD area?
Old 09-04-2006, 09:42 AM   #5 (permalink)
ok
Instrument cluster 94 swap motu 56 7th Generation (1993-1997) 4 03-17-2008 12:26 AM
sr5 gauge cluster swap jdmtoypickup Pre-88 Toyota Pickup/Hilux 0 08-28-2006 12:48 PM
Cluster Swap 01 corolla questions Rambo500 Archived Corolla threads 12 07-20-2006 10:07 PM
guage cluster swap? InfiniteLC Camry & Solara Lounge 6 12-08-2005 03:01 PM
Gauge Cluster Swap cheeba Camry & Solara Lounge 3 10-24-2003 03:28 PM
