need parts recommendation for 3sgte rebuild - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-31-2006, 06:53 AM   #1 (permalink)
View canadiancelica's Photo Gallery
Canada need parts recommendation for 3sgte rebuild
Bad compression on a couple cylinders. What should I replace/upgrade to put on more boost ?
Thanx
John
canadiancelica is offline   Reply With Quote
Old 08-31-2006, 07:05 AM   #2 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
what are your power goals/budget??....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 08-31-2006, 07:54 AM   #3 (permalink)
Would like it to hold 17 psi, would like to see 400+ at the wheels.
I know I need rings, gaskets, seals, probobly gonna get into cam bearings & water pump.
I need any recomendations on parts to look out for to replace (crank beairngs ?) and peformance parts I could use to aid me.
Budget is probobly 2-3thousand.
Old 08-31-2006, 10:39 AM   #4 (permalink)
your budget won't get you any where near the 400 range....i spent more than that just building my bottom end (arias pistons/eagle rods/arp studs/cometic HG/balanced crank/blueprinted motor)...and i'm in the 350 range but am also running HKS f-con and upgraded fuel system..w/o any head work (ie..aftermarket cams/intake manifold), it will be tough to hit 400..
91 mr2..07 335i..
Old 08-31-2006, 12:24 PM   #5 (permalink)
3SGTE & 1GRFE
View NESW20's Photo Gallery
the 3SGTE does not have cam bearings.
get forged pistons, rod and main bearings, all new seals/gaskets, cams, headwork (port & polish, cams, valves), cam gears, intake manifold, fuel rail/injectors/FPR/pump, large turbo, standalone EMS.
that's roughly $10,000 right there.
-Mike
1991 MR2 Turbo 2.1L stroker
2006 Tacoma D-cab 4x4 Auto TRD Off Road
NESW20 is offline   Reply With Quote
Fiberglass Parts MR2&S15 MR2 Forum 13 07-20-2004 10:11 PM
Main parts to an engine rebuild spills1969 Camry & Solara Lounge 3 05-10-2003 09:40 AM
85 TOYOTA COROLLA PARTS FOR SALE!!!! ANYTHING U WANT leafs4lyfe Archived Corolla threads 2 01-30-2003 08:25 PM
