DO your mr2 LEAK? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-04-2006, 10:00 AM   #1 (permalink)
View RedMK's Photo Gallery
DO your mr2 LEAK?
mine is leaking like it's raining inside too..
what is the most common way to fix that problem?
change the strip?
RedMK is offline   Reply With Quote
Old 09-04-2006, 10:50 AM   #2 (permalink)
View semi-charmed's Photo Gallery
you can change the seals...or i hear vaseline works sometimes
-Ryan
Project Turbo Two
semi-charmed is offline   Reply With Quote
Old 09-05-2006, 12:07 AM   #3 (permalink)
Gameroom cash: $134355
if it's an mk1 and a t-top... good luck
good friend bought an 87.... we got new t-top (and door) seals FROM TOYOTA...... still leaked like a motha-fucker..... we even tried the "weatherstripping RTV" trick that many people have done.... still leaked.... he sold the car only for that reason
the seals on the t-tops themselves leak.... and you have to buy new t-tops to get those seals....
Old 09-05-2006, 04:03 PM   #4 (permalink)
View Red October's Photo Gallery
Take the Tops off; get some good degreaser-type cleaner like an orange cleaner, and a lot of armor-all or such. Clean out the gaskets all over the windows and tops with the orange stuff. Get every little space there is, no matter how hard it is to get that space. There are a couple drains at the sides, let the orange cleaner run down these to help un-plug them. After it is completely clean, clean the backs of the T-tops where they mate to the car, and the gaskets on them. Then use the armor-all on the gaskets, applying like 4 or 5 coats at least. See how this works. Might work, might not. Cheaper and easier than replacing shit. This works in my experience with MR2s.... And trust me, you do NOT want to play with weather stripping!
The only time I "Asked someone about their Toyota", I ended up owning it.
Red October is offline   Reply With Quote
Old 09-05-2006, 11:13 PM   #5 (permalink)
thanks i will give it a shot.. i will update the result..
Old 09-10-2006, 08:24 PM   #6 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
that sucks... if you got new seals in there... check to make sure they were properly installed.
tHa kNiGHt FaLL is offline   Reply With Quote
Old 09-11-2006, 12:59 PM   #7 (permalink)
View vtsuckah's Photo Gallery
DO NOT do the above. Amorall will deteriorate the weatherstripping. Any oil based lubricant/protectant will deteriorate rubber/polymer materials. DO NOT use vaseline for it will do the same. There are rubber/weatherstripping cleaner/protectants that you can buy just for this purpose. Mequires makes a good product, same with Mother's "back to black".
Most likely, this will still not fix your problem. The revitalizer will not make your strips like new. Save yourself some time and effort by replacing both weather strips (on the ttop glass itself and around the roof opening). Once installed properly, you will notice how hard it is to lock your ttops. The old ttop weather stripping flattens out over time, making the seal loose. Replacing the strips cured my problem on my mkII.
vtsuckah is offline   Reply With Quote
Old 09-14-2006, 10:41 PM   #8 (permalink)
AH. That is what I used. I know it wasn't armorall per say; I just meant it as a generic. I honestly had no clue there were difference between such products.
Old 09-15-2006, 05:37 AM   #9 (permalink)
oooh yeah, big diff.
Old 09-15-2006, 10:58 PM   #10 (permalink)
.... back to black is meant for making unpainted bumpers and trim the not-faded color.... putting additives into the plastic
if you want to clean the surfaces.... use a cloth and rubbing alcohol
MR2 (2000+) Bodykit Possibilities (feedback wanted!) GryphonAuto MR2 Forum 2 05-27-2006 02:08 AM
Tercel and MR2 80tercelproject Tercel, Paseo, Starlet, and Sera Forum 8 02-12-2006 01:26 PM
MR2 Safety Product Thread. =-) MR2 specific safety products from safedrives.com Safe Drives Supporting Vendor Sales 8 10-17-2005 06:16 PM
considering buying a mr2. bowlofturtle MR2 Forum 17 11-07-2004 12:44 AM
