Speedometer Driven Gear - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-09-2006, 02:39 PM   #1 (permalink)
View tsbrownjr's Photo Gallery
Can anyone out there tell me how the speedometer driven gear assembly comes out of the transaxle case?
I've removed the machine screw and the small, flat tab that sits in a groove in the side of the assembly. It isn't clear at all what happens next. I'm guessing that tab fits in a slot so that it keeps the asembly from moving up or down. That would mean the assembly should just slide out, but it doesn't appear to want to come. I've used a large screwdriver as a lever in that groove and lightly tapped to see it would lift the unit, but no.
Any guidance from someone who's seen this would be appreciated.
tsbrownjr is offline   Reply With Quote
Old 09-09-2006, 03:00 PM   #2 (permalink)
Now with even more BOOST
View QuadCamSix's Photo Gallery
Are you talking about the actuall assembly with the teflon gear on it or just the speed pulse sender? If you are attempting to remove the driven gear its probably just a bunch of dirt or corrosion that is keeping the unit in place. Once the ten mm bolt is removed, grab the assembly and twist back and forth unitll it loosens up, then the unit will slide out. If the gear is damaged check other parts of the transmission aswell unless the damage was caused by a bad speedo cable.
MR2 V6 with an inordinate ammount of boost www.V6MR2.com
QuadCamSix is offline   Reply With Quote
Old 09-09-2006, 03:01 PM   #3 (permalink)
Should have said in the post - '85 AW11, 4AGE, C52 Transaxle.
Everything should be operational, that is no damage except I broke the upper, threaded part where the speedo cable screws on when I was trying to separate the bell housing from the engine!
There isn't alot to get hold of to pull out, but that's sort of what I expected I have to do. There is some dirt and grime around the top end of the unit.
Old 09-09-2006, 03:21 PM   #4 (permalink)
If the trans has 100's of K on it the assembly can be a bitch to get out. Try tapping it around the edge closest to the trans caseing with a flat head screwdriver and a small hammer(all around the base). Im assuming you have it out of the car of course
Old 09-09-2006, 07:59 PM   #5 (permalink)
Yes, it's out of the car, and has 120k miles.
So I'm tapping the outside edge of the sleeve, to get it loose moving in, then maybe prying outward in the groove where the tab holds it in place?
Thanks very much for your wisdom on this. Very reassuring to know someone's been here before.
Old 09-11-2006, 08:04 PM   #6 (permalink)
QuadCamSix you're my new hero!
Tapping (fairly heavily) a screwdriver blade into the groove around the edge of the sleeve freed it up eventually, and prying up in the slot for the tab finally started the whole assembly out.
It was indeed *very* tightly in there.
Old 09-12-2006, 08:18 PM   #7 (permalink)
Congrats, you must live near the ocean. That salt water vapor in the air always makes those things hard to remove.
Cannot shift into gear! SLC Punk Celica Forum 3 04-02-2009 06:57 PM
interesting article about double clutching boroEF Hardcore Tech and Competition 40 07-23-2007 01:12 AM
'05 Taco Speed/RPM charts Sonny 2nd Generation (2005+) 4 03-11-2007 01:08 PM
Speedometer madness Arved 89-95 Toyota Pickup/Hilux 3 03-04-2006 07:48 AM
Gear ratios for 2005 Tacoma 6 speed? lbmii 2nd Generation (2005+) 1 02-27-2005 01:17 AM
