Speedo - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-12-2006, 11:04 PM   #1 (permalink)
Rally_9RPM
redline_mr2's Avatar
View redline_mr2's Photo Gallery
Speedo
I have a 91 mr2 I just bought but it has the 93 motor inside. My speedo doesn't work and some of my idoit lights are on. But my rpm gas and temp and boost gauge work. Would just going out and buying a 93 cluster be the best thing to do? If so where should I start looking for one? If that isn't what I should look at what should I do? I was told the 91 is mechanial and the 93 is electric
redline_mr2 is offline   Reply With Quote
Old 09-13-2006, 01:38 AM   #2 (permalink)
sxlostv1's Avatar
View sxlostv1's Photo Gallery
my friend has the exact same problem. na swap to turbo. everythign works except for speedo. maybe needs a speed sensor from 5s-fe?
sxlostv1 is offline   Reply With Quote
Old 09-13-2006, 07:22 AM   #3 (permalink)
Rally_9RPM
It wasn't a none turbo before it was a turbo before just blown motor.
Old 09-15-2006, 06:57 PM   #4 (permalink)
View operatiofelatio's Photo Gallery
well yes the 91-92 speedometers were cable driven and the 93+ are electric. your problem is probably in one of 3 areas, are you using the 91 tranny? if you are using the tranny off the 93 the speedometer sending unit, which is in the tranny is, is electric and wont work. swap over the one from the 91. The problems with the mechanical sending are that the cable can fray or break or a gear may strip look at this site http://www.stephenmason.com/cars/mr2speedo.html for more info.
Good Luck
operatiofelatio is offline   Reply With Quote
speedo problem tjyota 4Runner Lounge 0 05-24-2006 12:15 PM
Correcting speedo error: will 265's fit? Activator 2nd Generation (2005+) 4 11-17-2005 07:46 PM
Bigger tires throwing off your Speedo? Sarkar 2nd Generation (2005+) 16 10-12-2005 02:44 PM
Broken Speedo, Help? Slip_87 ST Celica Forum 3 02-19-2005 03:34 AM
