changing the fel pump on a aw11 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-20-2006, 11:53 PM   #1 (permalink)
View celeritas's Photo Gallery
yo guys , i need to change the pump on my aw11 ... i read in my book that i need to drop the tank ...i was wondering if anyone here has ever done that job and if so , is it hard and do i have to draiin the tank ? ...its the final step to getting my car goin after the swap i did in my driveway!!! soo ya the pump is on its way ...im just tryin to get some info . thanks
celeritas is offline   Reply With Quote
Old 09-22-2006, 05:27 PM   #2 (permalink)
View mgd_only's Photo Gallery
yes i have done it and i hope you didn't reconect the fuel lines to that swap yet cause you have to have them not connected also you have todisconnect your emergency brake cables and the mounting braket that holds them then theres to hinged steel straps that hold the tank up to releses thoughs theres one pin on each strap u pull to free it but remember that tank isn't light and also don't forget to disconect the electrical connections to the fuel pump that are under the center armrest and it is a good idea to drain the tank cause mine was 1/4 full and it was heavy
mgd_only is offline   Reply With Quote
Echo 2000 check engine light Raistlin Yaris, Vitz and Echo Forum 19 03-26-2007 05:33 PM
Pay Before You Pump... RANT epinionator89 Off Topic 69 08-28-2006 09:37 PM
Walbro Fuel Pump, turbine pump? almc2242 Hardcore Tech and Competition 13 02-19-2005 09:08 PM
Where to get a oil hand pump for changing diff/MT fluid? varietta Archived Corolla threads 16 08-16-2003 12:28 PM
Changing CV boots, timing belt, water pump, spark plugs... Silver Streak General Discussion 4 08-03-2001 03:00 PM
