3rd gen 3sgte engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-21-2006, 01:56 PM   #1 (permalink)
MAX BOOST!!!!!!!
View mr2_dori's Photo Gallery
2nd Generation 3rd gen 3sgte engine
ok, i hear alot of different things on this. stock boost for the 3rd gen is 13-14psi. so what can i up the boost to where it would be safe. how much boost can a 3rd gen withstand?
mr2_dori is offline   Reply With Quote
Old 09-24-2006, 10:04 AM   #2 (permalink)
MAX BOOST!!!!!!!
so no one nows or can help me with this?
Old 09-25-2006, 10:55 AM   #3 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
What are your supporting mods?
Old 09-25-2006, 01:38 PM   #4 (permalink)
MAX BOOST!!!!!!!
2nd Generation
lol, whats up hommie. well right now i have tanabe downpipe, hks cam gears, hks thick headgasket. boost controller. then when i get the money im going to get that intercooler and exhaust, that maybe you can help me out with.
Old 09-25-2006, 04:44 PM   #5 (permalink)
Piddy's Avatar
As far as I know the stock boost is the same as all other 3sgte's... but the fuel cut is set higher. Before you touch the boost, you need to get a boost gauge. That will solve your main problem. You should be able to safely run 15psi. With that intercooler and maybe some WI for protection you can run 18 or so.
Old 09-26-2006, 08:55 AM   #6 (permalink)
MAX BOOST!!!!!!!
2nd Generation
sorry, i forgot to put these down. i have boost gauge, oil temp and exhaust temp. right now im running 14psi. its fine. but just wanted to now how far i can push it. where do you get your stuff done at. to your car that is. i have an exhaust leak right now and would like to fix it.
Old 09-27-2006, 09:44 PM   #7 (permalink)
View CompanyFlow's Photo Gallery
Leak due to what, bad gasket or cracked pipe?
CompanyFlow is offline   Reply With Quote
Old 09-28-2006, 11:24 AM   #8 (permalink)
MAX BOOST!!!!!!!
if i remember right the leak is from the upper cat to the dowmpipe. when the downpipe was installed they strpiied something. so i hear a little wistle when the car is warmed up. its starting to piss me off.
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 11:48 AM
3rd gen 3sgte mr2_dori Hardcore Tech and Competition 6 09-26-2006 09:00 AM
"A" engine info freakinbox Archived Corolla threads 29 05-10-2006 12:05 AM
3rd gen engine swap! nacho_nismo Hardcore Tech and Competition 2 08-05-2004 02:23 PM
2nd and 3rd gen engine. gC SwApS MR2 Forum 1 06-13-2003 09:45 AM
